Simple way to drain 71 blazer fuel tank
I've been laid up after having kidney cancer and felt like draining fuel tank after 5 years setting. My brilliant thought was to stick a harbor freight transfer pump hose thru the fuel filler opening. But of course with my luck the hose won't go in any further than about 16 inches.
So I have another idea about disconecting the tank line from fuel pump and place a cheap electric fuel pump connected to the line and drain that way. What are your thoughts. Don't want to do a lot of pulling and stretching. Can't think clearly being on these damn pain pills. Any thoughts would be appreciated. |
![]() Join Date: Jan 2001
Re: Simple way to drain 71 blazer fuel tank
My Blazer sat for 7 years and I was concerned about accumulated junk in the tank. I put a clear filter on the fuel line (temporarily) and topped the tank off with fresh gas. I watched it for the first week or so after I got it running and then changed it. I haven't had any problems.
If you really feel like you need to drain it, you could disconnect the fuel line and make sure it's in a container that will hold all the fuel that will come out. Then pressurize the tank with air. I've used a nozzle with a rag around it to seal it off. I wouldn't use more than about 10 PSI.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
simplest way...drive it.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
