Old 08-20-2004, 11:35 PM   #1
BUDDY
Global warming is a myth
BUDDY's Avatar
wiper harness
Hi. I'm wondering if any of you have & would be able to send me a windsheild wiper harness for my 72 blazer. I need a new one as I chopped my old one up, and the diagram I have is a little confusing about that circuit. Let me know & we'll set up a way for me to pay for it. My ZIP is 14228.
Thanks,
Buddy
BUDDY is offline   Reply With Quote
Old 08-21-2004, 06:22 AM   #2
JimKshortstep4x4
Smile
Since the wiring for the windshield wiper is integral with the interior wiring harness, you have a couple of options. You can buy the whole under dash harness or make up a custom harness. I am assuming that your existing under dash harness is beyond repair?
If you can get a good used under dash harness, that might be your best way to go.
Jim
Old 08-25-2004, 12:53 AM   #3
BUDDY
BUDDY's Avatar
Actually, the wiper wiring harness consists of a power wire from the fuse block that then is routed to the wiper switch & split somehow to power the washer pump as well. I am beginning to think that I could set them up independently of each other & just have a toggle for the pump. That would probably work, BUT, I figured that if somebody happened to have an old parts truck with somewhat intact wiring, that they might not mind chopping that part out of the underdash wiring and sending it to me. It would make my life a lot easier.
Also, the underdash wiring in my truck is actually gone because, I am still in the process of a complete re-wire.
Thanks for the reply, but I'd still be very gracious if someone could help me out with this.
Thanks,
Buddy
Old 08-26-2004, 05:06 PM   #4
337
I still got the same one from the last time.
it's complete from the fuse to the motor.
the wire colors are blue, light blue and black to the wiper switch.
2 connections to the wiper motor - yellow, blue and light blue with the ground connection. sent a pm
337 is offline   Reply With Quote
