Duramax swap
So I've got a 2 wheel drive 72 blazer sitting around along with a wrecked 06 2 wheel drive standard cab Duramax,bent the frame.
Curious on the people's ideas on the weight issue,I would think I could swap in some stiffer coil springs to support the massive weight the dmax Allison would add. Would a person really need to box the frame? I've seen many big block and hi horse applications thrown into these rigs without major frame modifications. Whatcha think people's? |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Re: Duramax swap
I would be afraid of the frame twisting up on a 1/2 ton.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach):2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
Re: Duramax swap
Hp is about 350 and torque is pushing 600 so I guess twist could happen at upper speeds,so we box the frame and possibly add some x bracing.
Pull the tub so we can access all and getter done,it's a plan! The hardest part is jumping in no matter what you do in life but I think this is doable. |
Re: Duramax swap
Do it!!! And don't forget to get the EFILive to clean up that lack of HP and torque
-Bruce 1971 K5 Blazer 4WD
Re: Duramax swap
![]() Join Date: Nov 2018
Re: Duramax swap
I’m running a 12v in a 68 C20 chassis, the fronts look identical from half to 3/4. Possibly slightly thicker metal but dimensionally the same. Point is I’m estimating with what I’ve done to be around 325-350 horse and 650-700 ft lbs. power isn’t what will kill the frame, it’s traction/load. Plus our c channel frames flex vs break, but personally something that short I wouldn’t put that much weight up front even though it’s be fun
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
#7 | |
Re: Duramax swap
#8 | |
Re: Duramax swap
#9 | |
![]() Join Date: Apr 2012
Re: Duramax swap
| Bookmarks |
