Old 03-02-2024, 11:27 AM   #1
Loose Screw
Loose Screw's Avatar
Mickey Thompson Sportsman S/T Radial All Season P255/60R15 102T Passenger Tire
Will these tires fit my worn out 1968 C10 long bed without hitting any of the fender? Also will they fit alright on my 6 lug rally style rims that came off a square body. The P235/75R15s I got on there right now look awfully small.
TIA
Loose Screw is offline   Reply With Quote
Old 03-02-2024, 11:37 AM   #2
pjmoreland
pjmoreland's Avatar
Re: Mickey Thompson Sportsman S/T Radial All Season P255/60R15 102T Passenger Tire
That size of tire and style of 15x8 rim hit the outer lip of my front fenders when hitting dips in the road. I have 2-1/2" drop spindles plus 1" drop springs in the front. I ended up going with 15x7 rims with 215/70R15 tires in front to solve the issue.
pjmoreland is online now   Reply With Quote
Old 03-02-2024, 11:48 AM   #3
Loose Screw
My worn out '68 long bed has the stock suspension...
Old 03-02-2024, 11:49 AM   #4
pjmoreland
pjmoreland's Avatar
Shouldn't be an issue then
Old 03-02-2024, 11:53 AM   #5
Loose Screw
Thanks Amigo!
Old 03-02-2024, 12:13 PM   #6
geezer#99
geezer#99's Avatar
If your 29 inch tall 235’s look small then your 27 inch tall 255’s will look much smaller.
Old 03-02-2024, 12:13 PM   #7
michael bustamante
michael bustamante's Avatar
I have 255-70-15 on my 8' rallye rims bno problem on a longbed ALL STOCK AND WORN SPRINGS
1967custom
michael bustamante is offline   Reply With Quote
Old 03-02-2024, 12:53 PM   #8
Loose Screw
a 235 is taller than a 255?
Old 03-02-2024, 01:10 PM   #9
Loose Screw
Yeah Ok, I see it on the Discount Tire Tire Calculator....
Thanks!
Old 03-02-2024, 01:13 PM   #10
Loose Screw
Those Mickey Thompsons are sure a cool tire though.....But Yeah I want a little taller tire, Not shorter....
Old 03-02-2024, 01:54 PM   #11
pjmoreland
pjmoreland's Avatar
Here's a truck I used to own that had 255/60R15 tires all around with stock height suspension.
Old 03-02-2024, 02:29 PM   #12
235/75 and 255/70 are pretty much same overall height. 255 just a tad wider. They should work great on you truck. I was running them on my 70 stock suspension long bed, no issues at all.
Old 03-02-2024, 03:40 PM   #13
Loose Screw
Ok, so I'm thinking these?
BFGoodrich Radial T/A 255/70-15 108 S Tire
So what do you all think? Good Lookin Tire, Not Too Outrageous, a little bit bigger all the way around.
Old 03-02-2024, 06:16 PM   #14
Good tire and size for a daily driven truck.
Old 03-02-2024, 09:37 PM   #15
Loose Screw
I had a Very Bad experience with MasterCraft/Cooper tires.
Name:  4RUNNER 2 (2).jpg
Old 03-03-2024, 01:03 PM   #16
Loose Screw
Will this size fit ok?
265/75R15 112S
Anybody running these?
Old 03-03-2024, 03:37 PM   #17
Should be fine
Old 03-03-2024, 03:47 PM   #18
Loose Screw
Should be fine
Thanks Amigo!
Old 03-03-2024, 04:26 PM   #19
Loose Screw
Ordered These! Thanks Everybody!
