Old 03-01-2024, 12:08 PM   #301
68 C10 Driver
Re: 1968 C10 Stepside Restoration Project
That steering wheel is not too much different from my 65 El Camino wheel when you put them side-by-side.
@raggedjim, I like the colors you picked! Keep in mind that you will need to build out the base of the steering wheel where it meets the truck's steering column. Truck steering wheels are a larger diameter at the center. I used a product called "All Metal". It is a body filler that has metal (aluminum) in it and makes for a hard surface when done. If i remember you only need to build it out about 1/8 to 3/16 in.
68 C10 Driver is offline   Reply With Quote
Old 03-01-2024, 05:21 PM   #302
68 C10 Driver
@raggedjim:
Here is what my 65 Camino steering wheel looked like before and after I built out the base. Note where the steering wheel and steering column meet.
Old 03-01-2024, 10:34 PM   #303
raggedjim
raggedjim's Avatar
Yeap, I've been building that base up and it is just about right. I hope I can get mine to the point yours is, it's a work of art.
Amazing how similar they are! I want to find a Chevy button that will fit in the same space as the Pontiac emblem.
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 03-03-2024, 01:06 PM   #304
68 C10 Driver
The one for the 65 El Camino should be a match.
Old 03-03-2024, 09:56 PM   #305
raggedjim
raggedjim's Avatar
I'll look into it, thanks!
Roger
'70 GMC Jimmy 2wd
Old 04-14-2024, 08:16 PM   #306
68 C10 Driver
So this weekend's main project was to install a pole barn style car port so I do not have to work on the frame in the blazing sun this year. Great product from a local builder.
First photo is the site for the car port, just next to my shed. Second photo shows the materials when delivered. Third is a little more than halfway through the process, and last photo is the completed carport. Car port is 20 x 20.
This car port will also be where I park the truck. The garage will not be big enough to handle having it, my MG, and our classic Mini when it is done.
Old 04-14-2024, 08:54 PM   #307
zicc1835
zicc1835's Avatar
nice....
zicc1835 is offline   Reply With Quote
Old 04-14-2024, 09:17 PM   #308
68bowtie
68bowtie's Avatar
Looks great!
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
Old 05-06-2024, 08:31 PM   #309
68 C10 Driver
So I got out today to do some de-rusting of the frame, all the while enjoying the shade from my new car port. stripping rust off of a truck frame is not an easy task, especially when your primary weapon is a hand grinder with a wire wheel on it. Not only is it loud (had my ear protection on), but it really gets old fast. Those heavy duty wire wheels work great, but occasionally throw those wires at you. Definitely wear a face shield when doing that task.
Sprayed Rust Mort on the frame after I wire brushed it. Should not flash-rust. I will eventually use the Eastwood Rust Encapsulator and Satin Black 2k frame paint when the rust removal is done.
Old 05-06-2024, 09:09 PM   #310
zicc1835
zicc1835's Avatar
looking good lots of work been there and done that .....I cheated and had the second one I did blasted keep at it.... and your right watch them flyin wires off the wheel you may want a blacksmiths apron
Old 05-07-2024, 09:08 AM   #311
raggedjim
raggedjim's Avatar
Wire wheels, I use them but I don't like them! Nice work!
Roger
'70 GMC Jimmy 2wd
