Old 03-13-2024, 12:34 PM   #1
Loose Screw
Loose Screw's Avatar
Fuel Line Question...
I've heard people talk of some sort of fuel line that is fairly easy to work with.
What's that line called? Will it splice onto Steel line?
I want to familiarize (test stuff) myself with what's out there before eventually putting my gas tank in the bed....Thanks!
Loose Screw is offline   Reply With Quote
Old 03-13-2024, 01:07 PM   #2
notsolo
notsolo's Avatar
Re: Fuel Line Question...
Nickel copper brake line,fuel line, easier to bend and flare
notsolo is offline   Reply With Quote
Old 03-13-2024, 04:06 PM   #3
HO455
HO455's Avatar
X2. Sometimes referred to as Nico or Nicop.
Out of curiosity how are you planning to space the lines?
RIP Bob Parks.
Old 03-13-2024, 04:06 PM   #4
Loose Screw
I'm surfing...Earl's Vapor Guards......and PTFEs...
Anybody using these softlines?
You know and it's 'funny', I've even seen artist go and do all this Beautiful Hardline Bending and Still clamp in some Rubber hose somewhere in the fuel delivery system...
Old 03-13-2024, 04:12 PM   #5
HO455
HO455's Avatar
There are places that require the flexibility of a hose to absorb vibration that would end up work hardening and eventually cracking a metal tube.
RIP Bob Parks.
Old 03-13-2024, 04:13 PM   #6
Loose Screw
As for "Spacing", I guess on the inside of the frame and as far away from anything Hot.
Old 03-13-2024, 04:22 PM   #7
Loose Screw
Yeah in my life I've never had rubber line let loose on me. I am more aware of rubber fuel line though and have replaced when it was looking stiff and dry Before it let loose....That said I used to Never check metal fuel line, well because it's Metal...and Yes I had Metal line split on me...Now I check it.
Old 03-13-2024, 04:26 PM   #8
LS short box
Times 2 on the NICOPP. Technically its brake line but works great for fuel line. You can buy it in sections flared on both ends or bulk lengths. I get it at Oreilly's.
Flares like butter.
I use the rubber lined "Adel" clamps to hold the line to the frame.
LS short box is online now   Reply With Quote
