Old 03-17-2024, 04:14 PM   #1
pound41
1980 K10 Keep air pump or delete
Hello
I have a 1980 K10 350 4spd Ac truck.All my others are pre air pump trucks. I need to replace the carb. Wondering if I should eliminate the Air pump and all that goes with it. There's vacuum lines going every where. Thanks for your thoughts
pound41 is offline   Reply With Quote
Old 03-17-2024, 06:38 PM   #2
geezer#99
geezer#99's Avatar
Re: 1980 K10 Keep air pump or delete
Do you have to pass a visual inspection come smog test time.
What carb are you going to use?
Old 03-17-2024, 07:05 PM   #3
pound41
Nope don't have to pass any emission tests. Thinking of just a quadrajet with electric choke.
Old 03-17-2024, 07:45 PM   #4
geezer#99
geezer#99's Avatar
Not a lot to be gained ripping stuff out. Looks better maybe but might cost you 10 hp at 5 grand.
Old 03-17-2024, 08:12 PM   #5
smupser
Active Member
How exactly is he going to be losing horsepower by ripping the air injection off??? injection does nothing for performance. And if anything, it’s one less accessory that you’re driving, which could gain power.
smupser is offline   Reply With Quote
Old 03-17-2024, 08:25 PM   #6
geezer#99
geezer#99's Avatar
Well gosh darn I worded that wrong!
Would you like me to try again?
Old 03-18-2024, 05:48 PM   #7
Dead Parrot
Delete. You won't unlock 50 hidden HP but at this age, the air pump could fail at any time. Might as well pull everything during the carb swap. Check the threads on the plug sizes needed for the manifold holes.
Dead Parrot is offline   Reply With Quote
Old 03-18-2024, 06:28 PM   #8
pound41
Thanks I know it won't change HP much one way or the other. I was more concerned with having to chase leaks in all the vacuum lines and plastic T connectors it has a lot. I didn't want to replace all of those.
Old 03-18-2024, 06:38 PM   #9
Shifty One
Shifty One's Avatar
Save the parts.....take a look at what a.i.r. pumps go for now, assuming you can find them, that is.
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 03-18-2024, 06:49 PM   #10
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: 1980 K10 Keep air pump or delete
just don't bring the truck to "the people's republic of commifornia" and try to smog it, LOL. by the way I just sent in my renewal for my 80 K20 this morning $304.00
as someone else said take it off but don't throw it away.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
