![]() Join Date: Feb 2016
3.07 gear set.
I have a good used set of 3.07 gears. Removed from my 12 bolt so I could install 3.73's.
$50 plus shipping from 97217.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Re: 3.07 gear set.
Still for sale. Gears are not rusting, the setting sun added a reddish tint to photos.
Re: 3.07 gear set.
Bump for gas mileage.
Re: 3.07 gear set.
Cheap overdrive.
Re: 3.07 gear set.
Bump to the top
Re: 3.07 gear set.
To the for the new year!
Re: 3.07 gear set.
Bump for spring!
Re: 3.07 gear set.
Not to hijack your thread, but how do you like the change in the gearing. I am looking into possibly doing the same gear change. Did you see a large drop in mileage? Hope about off the line pep.
Good Luck with the sale. |
Re: 3.07 gear set.
I really like the 3.73's. Much better off the line. I didn't check the mileage when I had the 3.07 gears but I gotten high as 14.4 mpg with the 3.73's without the OD and in the 15 mpg with the OD. I don't remember there being much difference in mpg when I swapped gears.
Re: 3.07 gear set.
Bump for a summer project.
Re: 3.07 gear set.
Trip to the top.
![]() Join Date: Jun 2005
Re: 3.07 gear set.
Any idea what brand and how many miles on the gears?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Re: 3.07 gear set.
As far as I know they are original GM gears.
I got the axle out of a running and driving truck with 80 or 90k miles (I'm not 100% sure of the mileage) that had been recently wrecked. I got the axle out of in 2021 when my Burban had been hit in a wreck and it's axle housing was bent. I had my rebuilt axle internal parts removed from the bent housing and installed in the new housing. This gear set was from that.
Re: 3.07 gear set.
Ok. Unless there are other numbers on the gears, they are not GM. Original gears will have GM part numbers. I don’t recognize that logo.
#15 |
Re: 3.07 gear set.
You sound like your more knowledgeable about it than I am. Here is a link to when I got the axle the gears came out of. Scroll to post 790. Rereading now it does appear, by the stamped axle code, that the gear set had been replaced at some time in the past . Maybe it was back in the 70's? I don't know.
https://67-72chevytrucks.com/vboard/...698377&page=32
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 11-10-2024 at 12:05 PM. Reason: -2 grammar. |
#16 |
Re: 3.07 gear set.
Bump for the new year. OBO.
#17 |
Re: 3.07 gear set.
Will that fit in one of those U.S. Postal flat rate boxes?
#18 |
Re: 3.07 gear set.
I don't know. I have the set currently in a ring and pinion box with the styrofoam packing. I will do some measuring and let you know.
#19 |
Re: 3.07 gear set.
No it won't fit. It's 11x15x6 inches.
