Old 08-21-2004, 09:05 PM   #1
will2k2
Rallye wheels
I went to the junkyard today and picked up a set of 4 Chevy truck Rallye wheels...the common ones seen everywhere.
Ok, well...after starting to clean them up, I noticed that 3 were the same and 1 was either a lot wider or the backspacing was different. It looked like it was at least one or 2 inches wider. That isnt a problem..in fact I plan to get another to match it for the rear. My question is..what are these wider Rallye's found on normally? It's a 5-lug and has the cap that bolt on from the front.
Thanks!
1975 Cheyenne
350 2bbl, TH350, 3.42 rear.
Rosewood/white insert
will2k2 is offline   Reply With Quote
Old 08-21-2004, 09:17 PM   #2
beaterC10
Vans generally had 6.5" ralley wheels, pickups could have 7" or 8" on the 73-87 trucks. The later trucks seem to have 7" wheels.
beaterC10 is offline   Reply With Quote
Old 08-22-2004, 02:25 AM   #3
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
They are stamped on the inside of the rim 15x7 or 15x8 if they are stock rims.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 08-23-2004, 07:49 PM   #4
GMCLS1
1987 GMC Sierra Classic
GMCLS1's Avatar
I'll swap you a stock freshly painted 15x7 rally for your 15x8 if you want to have a matching set of 15x7 wheels.
Gary L Hilton jr
GMCLS1 is offline   Reply With Quote
