#36 |
Re: finally come
Hey all, for my lift jig I just measured to the outside door pinch weld. I used 2x4’s with enough space in between the 2 long beams to have room for the hoist arm to fit there. I used the hole on the arm where the lift chain would go to attach a threaded through both beams with washers and nuts on either side. The 2 beams had a block maybe 12” long attached to each end as the secure block catching on the door pinch weld. I hope that helps...
| Bookmarks |
