Old 03-29-2024, 11:47 AM   #4701
67C10Step
67C10Step's Avatar
Re: What did you do to your truck today.The 3rd chapter
Hopefully in the short rows of a power steering install on my 67. Everything has gone about a smooth as expected to this point. Waiting on new hoses as the initial ones I purchased I did not like the way they fit.
It looks like the power steering box I installed is going to cut about one full steering wheel turn from lock to lock. I will have to learn how to drive the truck all over again.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 03-31-2024, 01:52 AM   #4702
pjmoreland
pjmoreland's Avatar
Installed this crossmember that moves the trailing arm attachment upward and provides more clearance for the driveshaft to be higher. This allowed me to raise the rear of my transmission to improve the u-joint angles.
pjmoreland is offline   Reply With Quote
Old 03-31-2024, 02:01 AM   #4703
'68OrangeSunshine
'68OrangeSunshine's Avatar
I like your cross-over exhasust pipe.
Old 03-31-2024, 02:05 AM   #4704
pjmoreland
pjmoreland's Avatar
The guy who built my exhaust system just decided to do it that way. Not sure why.
Old 03-31-2024, 02:47 AM   #4705
'68OrangeSunshine
Well, if you didn't know -- It's an old hot rodder's trick.
The pulses from one bank of cylinders cancel out the pulses from the other bank, resulting in less perceived noise to human ears.
[Dogs, not so much.]
Also helps scavenging to increase low end torque.
I have it on my '71 Jimmy. Crossover is behind the transfer case. Symetrical with a V8.
With an L6, cylinders 1-2-3 have the forward collector, and cylinders 4-5-6 have the aft collector. So the cross-over has to slant diagonaly to occlude each other's detonations. [So an ''N'' pipe instead of an ''H'' pipe.
My C/10 Stepside was set up in the '80s at Simmons' Engineering in Tucson. My project mechanic was an old country boy Circle Track hand. He knew a few old tricks as Chevy Sixes were preferred in that event due to their quicker hole shot response.
X-Pipes are supposed to have the same effect, but I think when they channel down into one double tube, they don't get the scavenging the two interconnected tubes get.
IDK. Probably a good topic for someone with a Dyno and no other obligations than to pursue automotive research.
Old 03-31-2024, 12:07 PM   #4706
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
Nice weather this weekend so yesterday finally got the C10 on the road to put some miles on the new 327 and 5 speed to fully shake it down. Stopped at a museum that had some planes parked outside for a picture.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 03-31-2024, 12:29 PM   #4707
PbFut
That's a nice pic. Reminds me of when I lived closer to Miramar. At that time a naval air station and home of Top Gun. (1980s) The Blue Angles came to town every year. What a show. It's all Maine now, but I think the Angles still do a show. If you have not seen a Blue Angle air show, it should be on your bucket list. TV does not do justice. Top fuel drag race and Blue Angles are must see live events.
PbFut is offline   Reply With Quote
Old 03-31-2024, 02:16 PM   #4708
CAMAROBOY68SS
Thanks, I grew up neat a small airport that would do the state air show every year and either the Blue Angels or Thunderbirds would come to town. The house we lived at was in the flight path for them so we would just get on the roof and watch them all day. Was always amazing, plus would then see all the older planes make laps.
The Twins:
The "Others"
2017 Camaro SS
Life long Chevy guy
Old 03-31-2024, 02:48 PM   #4709
Sheepdip
Sheepdip's Avatar
Otis is done that way, the truck had brand new Magnaflow's on it when I got it, but were way too loud and raspy for me, so my muffler man said this will tone it down, and it did...a lot. It makes the distinct left/right exhaust tones blend to a more pleasurable combined tone.
Sheepdip is offline   Reply With Quote
Old 03-31-2024, 03:08 PM   #4710
KQQL IT
At the body shop.
KQQL IT's Avatar
1904 Qjet hopefully leaks less than the 45 yr old one before.
Old 04-01-2024, 07:09 PM   #4711
72c20customcamper
72c20customcamper's Avatar
Already been told no “While it’s apart I might as well” cleaned the crude off the upper control arms truck has the original ball joints .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 04-02-2024, 01:35 AM   #4712
Rust_never_sleeps
Rust_never_sleeps's Avatar
Finally finished my speaker "enclosure" and bolted it to the dash
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
Old 04-02-2024, 12:24 PM   #4713
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
That's one of the nicest trucks I've seen.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 04-02-2024, 09:08 PM   #4714
72c20customcamper
Got the engine out today
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-03-2024, 04:05 PM   #4715
72c20customcamper
It’s a good thing that the engine leaked oil everywhere .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-03-2024, 04:08 PM   #4716
72c20customcamper
And the list gets longer by the day
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-03-2024, 07:00 PM   #4717
72c20customcamper
Nothing like working on a west coast truck
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-04-2024, 01:24 AM   #4718
pjmoreland
pjmoreland's Avatar
That is some clean sheet metal
Old 04-04-2024, 08:55 AM   #4719
Jiggers72-GMC
Jiggers72-GMC's Avatar
Nice work so far Mark, well done man
when I was cleaning my frame, I was always excited to see numbers ...........
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 04-05-2024, 03:55 PM   #4720
72c20customcamper
Cleaned up the old block . 3500 psi hot water pressure washer
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-05-2024, 08:02 PM   #4721
72c20customcamper
Frame came out real nice with the hat pressure washer . All the original brake lines look new . The pressure washer rental cost me $96 for the day I would do it again in a heartbeat.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-06-2024, 11:59 AM   #4722
Steeveedee
Who Changed This?
Steeveedee's Avatar
That came out nice, and you didn't even have to take the washer off the trailer. Mighty handy.
~Steven
Simi Valley, CA
Old 04-06-2024, 04:13 PM   #4723
weq92f
weq92f's Avatar
Started prepping to replace the water pump today. Decided the radiator and fans needed to come out so I started draining it and unhooking lines and hoses. The goal was not to make a mess. With that in mind I decided to move the truck out of the shop onto the gravel to remove the radiator and pump, this way any coolant in the block could just run out there. OK! I hop in the cab and fire it up, pull it into reverse and didn't get that immediate thump into gear...it took me maybe a second to go from I'm gonna move this truck to engine OFF NOW!
...and so now I get to do exactly what I was trying to avoid, and then some!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 04-06-2024, 06:44 PM   #4724
72c20customcamper
I just painted everything black since it’s a driver
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-06-2024, 09:07 PM   #4725
67C10Step
67C10Step's Avatar
Not on my truck, I just drove mine to my buddies. New power steering is working great and wish I’d done that swap sooner.
Helped my buddy get his radiator in, all hooked up, and filled. We then rebuilt the driveshaft with all new u joints and carrier bearing. Got right the point of ready to fire up and ran out of time. Ready for first start and break in after full rebuild.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
