Old 04-03-2024, 04:55 PM   #1
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: L6's with Offenhauser 4 barrel
Originally Posted by old51sedan View Post
Just curious how many of us are running a 250/292 with an Offenhauser intake and a 4 barrel carb along with cast iron headers. Mine is cold blooded as can be so I just ordered a plate to mount under the carb. It talks about running water through it to warm things up. My idea is to run the exhaust vapors through to do the same thing. Would appreciate any input.
On my 292, I have the Offy intake and Clifford Headers. Four Bbl Edelbrock Performer EDL-1404, 500 CFM. I have no carb heat set up.
Running in Southern AZ, I don't think I need it. But it does perform better in high summer -- when the Snowbirds are longgone.
Old 04-06-2024, 09:54 AM   #2
old51sedan
old51sedan's Avatar
I received the plate, now I believe I'm going to drill a hole in each one of the exhaust pipes just below the headers and weld a nut on similar to the way they install an oxygen sensor , then run some 3/8 copper to the plate. This is what I used on my 51 sedan and it worked well.
old51sedan is offline   Reply With Quote
Old 04-12-2024, 07:55 PM   #3
MikeB
MikeB's Avatar
Have you thought about a way to block-off that tubing when the engine warms up? Might be something out there that would work, like one of the 80s emission control doo-dads.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is online now   Reply With Quote
