Old 04-01-2024, 07:37 AM   #1
J&J67C10
67 C10 V8 Correct Exhaust Manifolds
Hello all, simple question, I hope. What would the correct ram horn exhaust manifolds be for a 1967 C10 with a 327 be? Straight drop or angle drop? When we bought our 67 it had a transplanted 350 in it with a straight drop manifold on the passenger side and an angle drop on the drivers side. I am in the process of installing a new exhaust system and I would like to put the correct drop manifolds on as part of the job. Thanks, JandJ.
J&J67C10 is offline   Reply With Quote
Old 04-01-2024, 02:13 PM   #2
58 Special
Re: 67 C10 V8 Correct Exhaust Manifolds
Not an expert but I believe the straight down drop ram horns were for 4WD
58 Special is offline   Reply With Quote
Old 04-01-2024, 02:28 PM   #3
chewychevy67
Angled for 2wd straight down for 4wd.
chewychevy67 is offline   Reply With Quote
Old 04-01-2024, 09:22 PM   #4
too much stuff
Roadtrip!
too much stuff's Avatar
I always thought this also but i have seen a straight and an angled on 2wd before. i don't recall which one was where, but wondering if a manual trans could have had a straight dump on the driver side? Or if one had been changed out at one time.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 04-02-2024, 08:37 AM   #5
J&J67C10
Thanks for the help so far. I'm on the fence as to how I'm gonna work this. I did some research and it seems either way works. I have a driver side straight dump to use so I'm covered there. I plan on taking the manifolds off to run the plug wires correctly so I'll do some mock up and see which will be the better choice.
Old 04-02-2024, 09:08 PM   #6
MikeB
MikeB's Avatar
I think 67-68 283-327 would have had straight dumps, because the engines were mounted in the rear location. Even for 2WD.
I learned that when returning some headers that wouldn't clear my 69's motor mounts, because they dumped straight down.
Mike
1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 04-02-2024, 11:37 PM   #7
J&J67C10
Interesting, the frame mounts on our truck I believe are in the front holes, was that way when we got it. The truck was originally a 292. I'll do some mock up when I get to that point. Plug wire routing is next on the list.
Old 04-04-2024, 09:21 AM   #8
NGN
NGN's Avatar
Angled back both side, in both my 67 TWD V8 , one three speed manual one 350 auto.
NGN
Nick
NGN is offline   Reply With Quote
Old 04-04-2024, 11:10 AM   #9
MikeB
MikeB's Avatar
Check this out: https://www.lmctruck.com/1967-72-che...and-components
Looks like 67 was straight on both sides, but 68 was straight on drivers side, and angled on passenger side. And when you get into 69, it's a function of 2WD or 4WD, because engines were mounted forward in 2WD trucks. All that's assuming LMC is correct.
Enough to make your head explode!
Mike
Old 04-04-2024, 11:23 AM   #10
chewychevy67
I've had 2 67 2wd and 1 with 283 original and 1 327 original. Both were angled. I'm in Canada so maby it's done differently down there. Never had any 4wds.
Old 04-04-2024, 03:43 PM   #11
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Don't ever rely on LMC being correct. I don't know about the rest but 67 2wd are both angled back.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 04-04-2024, 07:44 PM   #12
425HP409
425hp409
425HP409's Avatar
My original 68 with a 307 was both angled back.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 04-05-2024, 08:32 PM   #13
J&J67C10
Hopefully get out to the shop this weekend and tie into this project. Dang back has been giving me grief all week. This getting old business isn't for the faint of heart.
Old 04-05-2024, 10:20 PM   #14
R.O.B.
My 67 C20 had them angled. And when I bought a set of straight down the middle, it was like 2.5 inches from the crossmember, no way to plumb an exhaust.
Factory 327
R.O.B. is offline   Reply With Quote
Old 04-05-2024, 10:31 PM   #15
J&J67C10
Guess I'm not following, Which cross member are you referring to?
Old 04-06-2024, 12:22 AM   #16
R.O.B.
The front crossmember, the one that the control arms bolt to.
Old 04-06-2024, 02:02 AM   #17
lil hoodlum
lil hoodlum's Avatar
I'm not sure on the 67's, but on both of my 1968 C10 and C20 with 327s the exhaust manifolds are angled back.
I too thought that the K10s and K20s were straight down.
1968 C10 327, 3 speed manual, LWB stock height daily driver.
1968 C20 327, 4 speed manual, LWB stock height custom camper with heavy duty leaf springs rear, 50th anniversary edition. Hoping to press into daily drive status soon.
lil hoodlum is offline   Reply With Quote
Old 04-15-2024, 02:41 PM   #18
SJLenz1340
My 67 w/327 has the rear facing exhaust exit as well. I also had the alternator mounting points at #1 cylinder position, good luck trying to find one of those!
Regards
Steve
SJLenz1340 is offline   Reply With Quote
Old 04-18-2024, 11:16 AM   #19
KyleSeal
KyleSeal's Avatar
My 1967 C10 (283 V8) had angled manifolds. With a cast bracket on the manifold for the alternator.
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 04-18-2024, 11:26 AM   #20
Ironhorse
Ironhorse's Avatar
Since these trucks are going on 55 years plus in age a LOT of things were changed and some even cobbled thru the years by previous owners. I have a set of angled back both RH and LH original GM rams horn exhaust and the website I use says correct for 64-68 283, 307 and 327 two wd trucks. Won't work on my '71 4x4 K10, if interested in them send me a PM and I can get some pics for you.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 04-18-2024, 01:50 PM   #21
damnyankee36
damnyankee36's Avatar
For what it's worth, the 68 2WD, 327 I'm restoring had angled manifolds. It was mostly unmolested so I feel confident they were the original manifolds.
The customer wanted to keep the rams horn style so we went with an aftermarket 2 1/2" outlet design. Like R.O.B.'s post, they are straight down and in was PITA to custom fit the exhaust to them. There isn't much room to fabricate due to the close proximity to the crossmember.
As MikeB mentioned, if the engine was moved back an inch or so, like the 4WD's, it would have made it much easier.
1966 C10 Custom Cab Restomod (Sold)
1969 Camaro Z/28 (Keeper)
Current Build: 1968 C10 (Semi-Factory Restoration)
1983 Camaro Z/28 (Next in line, Keeper)
1951 3100 (2nd in line)
damnyankee36 is offline   Reply With Quote
Old 04-18-2024, 08:29 PM   #22
J&J67C10
Hey thanks for the help on this. Yes I believe the correct setup is angled ram horn manifolds for 2wd applications. As I said our truck came with a straight drop on the pass side and an angle drop on the driver side. I am still debating what I will do. Of course I have 3 straight drop driver side manifolds to choose from. My back is still giving me grief and up and down under an old truck is not real great for healing. All in good time.
Old 04-19-2024, 07:07 PM   #23
Chaparralman1974
Chaparralman1974's Avatar
Just to add to this thread, my 67 K20 has center dump manifolds on both sides. Mine is a 327.
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272
Chaparralman1974 is offline   Reply With Quote
Old 04-20-2024, 10:42 AM   #24
MikeB
MikeB's Avatar
That makes sense with an engine mounted in the forward position, because the driver's side heads sits farther forward than the passenger side. So the angle is needed to clear the motor mount (or cross member?) -- I forget which. I just remember trying straight ones on my 69 C10 and there was no room for a down pipe on the driver's side. Then again, I was trying to install 2.5" rams horns, which have a much larger body.
Mike
Old 04-20-2024, 01:46 PM   #25
damnyankee36
My situation exactly. With these manifolds I had less than 1/4" clearance from the motor mount. I had to splice and cut a bend but to clear the crossmember but it didn't make for a very pretty bend. A bit of an irregular shape.
