has anybody used the power disc brake conversion kit from early classic? if so is it a quality kit? or is there a cheper alternative other than taking chances on bone yard stuff?
cheapest way is to get the whole assembly from rotor to rotor off a 71-81 pickup (up untill they went to metric) the kits for these trucks are basicly drop spindles that are made to use the rotors calipars etc from these newer trucks
------------------ www.xframeimpala.com 68 4x4 short fleetside deluxe cab 327 air 56 big window short stepside 64ImpalaSS 327 700R4 67 1 ton dually 157" wheelbase 327 SM420 |
Beware
You can get all of the parts you need from a salvage yard, but watch the spindles. there are two different types. If you get them from a 72 model they are a perfect fit, but if they are like 77 and later make sure the rotors are 1-1/4 inch wide as they are the right spindles.
Raphyel |
![]() Join Date: Sep 2000
sent you a PM
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
