Old 04-06-2024, 12:02 PM   #1
r.e.c.enthusiasts
Disc/drum master cylinder
Okay. So I purchased a while back a western chassis Master cylinder for my disc /drum setup. But now my front discs are dragging. When I release the pressure at the bleeder valve the brakes release and wheel spins freely. Sadly I know when I was installing the setup some debris got in the reservoir. I thought I cleaned it out. But it's possible I got some tree pollen in there.
So that's where I will start. I don't like Western chassis any after dealing with them. Where can I get a suitable Master cylinder to replace what they had? My truck 69 Chevy c10 front disc rear drum, the discs, prop valve, and all other hardware are from cpp through summit racing.
r.e.c.enthusiasts is offline   Reply With Quote
Old 04-06-2024, 12:15 PM   #2
dmjlambert
dmjlambert's Avatar
Re: Disc/drum master cylinder
Power or manual brakes?
Old 04-06-2024, 12:24 PM   #3
r.e.c.enthusiasts
Manual.
Old 04-06-2024, 12:31 PM   #4
weq92f
weq92f's Avatar
I have some air in my lines in the front. When that air heats up after repeated braking events like stop-n-go, my front discs drag a little.
I suspect your issue is not that, but it's worth a mention.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 04-06-2024, 12:37 PM   #5
dmjlambert
dmjlambert's Avatar
I recommend NAPA part M36280 new master cylinder for manual-brake 1/2 ton C-10 disc/drum. https://67-72chevytrucks.com/vboard/...39#post9169739
First, bleed the brakes to make sure you don't have air in the lines. If you have old rubber brake hoses, replace those because they could be your problem.
Old 04-06-2024, 01:43 PM   #6
r.e.c.enthusiasts
Thank you.
No issues with the rubber hoses. All new.
I will try to reverse bleed again.. When I put the new master on I'll be reverse bleeding into it after bench bleeding.
Old 04-06-2024, 01:57 PM   #7
MikeB
MikeB's Avatar
What type of master cylinder was on the truck previously, and why did you replace it?
Are the calipers also new to the truck?
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 04-06-2024, 03:17 PM   #8
dmjlambert
dmjlambert's Avatar
Originally Posted by r.e.c.enthusiasts View Post
Thank you.
If you reverse bleed after bench bleed, wouldn't that just push air up into the master cylinder and you would lose any benefit of bench bleed?
Old 04-06-2024, 05:30 PM   #9
Sheepdip
Sheepdip's Avatar
Double Check your MC push rod for proper clearance from the M/C piston contact point. Should be 1/16"-1/8" ....Sounds like your vent port is getting slightly covered and holding pressure
Sheepdip is offline   Reply With Quote
Old 04-06-2024, 06:28 PM   #10
r.e.c.enthusiasts
So I know there is a decent clearance between pushrods and MC on full release
Old 04-06-2024, 10:46 PM   #11
MikeB
MikeB's Avatar
I know you meant "holding vacuum", but good call.
Mike
Old 04-07-2024, 01:24 AM   #12
r.e.c.enthusiasts
When brakes are applied pressure is applied all the way to the pads. When brakes are released. There should be release vacuum but there is not. It is holding pressure at the caliper. When I release the bleeder screw the pressure that is still lightly holding the rotor is then released.
I did have the fluid flushed and filled at Les Schwab. The brakes to engage well. But after a while begin to drag.
Old 04-07-2024, 01:52 AM   #13
lil hoodlum
lil hoodlum's Avatar
My first thought is the brake hoses are failing, but you said the brake hoses are new.
1968 C10 327, 3 speed manual, LWB stock height daily driver.
1968 C20 327, 4 speed manual, LWB stock height custom camper with heavy duty leaf springs rear, 50th anniversary edition. Hoping to press into daily drive status soon.
lil hoodlum is offline   Reply With Quote
Old 04-07-2024, 09:00 AM   #14
geezer#99
geezer#99's Avatar
Does your master cylinder have residual check valves in it?
If it’s a drum/drum master then it might have a 10# check valve for the front when it should have a 2# in it.
geezer#99 is online now   Reply With Quote
Old 04-07-2024, 05:13 PM   #15
Rust_never_sleeps
Rust_never_sleeps's Avatar
Interesting. I was not aware there was a residual valve built into the MC at all.
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
