Hotwheels?
Easiest way to get to front springs?
Pop the balljoint on the LCA or the u bolts to it? My book says U bolts, but I dont wanna do that and I have a feeling it would be much simpler to get it out with a jack and the balljoint, wouldnt need a spring compressor then.
1978 Money Pit - CUSTOM DELUXE!!!! |
Back from the Dead
I've done both methods and I found the LCA Balljoint is easiest after doing it plenty of times! Good luck,
KEnny
The only Carb that matters to me is the one under my hood! Salem, Oregon |
All Go, No Show
i undid the ubolts, first time doing it so I don't know how hard the balljoint way is but the other way is pretty easy, no spring compressor is needed either way I would imagine at least I never needed one, again Good Luck either way
69 LWB Rebuilt 283, aluminum intake, edelbrock carb, Mild Melling Cam, HEI. |
i like the balljoint method
On our trucks, the lower balljoint castle nut is easiest, then let down the jack and watch out.
Hotwheels?
well of course you anchor down the spring. :p
