Old 04-22-2024, 10:20 AM   #101
loudchevy
Active Member
loudchevy's Avatar
Re: "BUILD: 1970 C10 LWB--->SWB “Jumping Cholla”
I wasn't gonna do anything with the bed for a while, but I needed a change of scenery from bodywork. It's only going to get warmer from here out in Phx (90*ish in the garage already) so I decided to break down the bed so I can get it cleaned up and shortened. I only got (4) carriage bolts to come off cleanly. The rest took a combination of drilling, grinding, punches, and a BFH. The best approach was cutting a slot in the top to use a flathead screwdriver to hold the bolt and impact the nut off from the bottom, but that didn't always work out as some the bolts couldn't get a cutoff wheel on them. Overall, it took around 5 hours to break the whole bed down. If anyone needs the fiberglass toolbox insert that comes with the LWB toolbox option, hit me. The one I removed is in good shape.
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 04-22-2024, 10:27 AM   #102
loudchevy
Active Member
loudchevy's Avatar
Couple more pics....I also removed the stake pockets from the driver's side panel. I was going to cover the openings on the top rails anyways. The passenger side panel is banged up around the wheel well and it has the giant opening from the toolbox, so I'm not going to cut that side down. I'll be looking for a LWB or even better SWB panel to use in its place. The crud pile from the bottom of the bed was smaller than I thought it would be. At least it's a dry heat, right?
Scott
2003 Tahoe Stock
Old 04-22-2024, 10:44 AM   #103
raggedjim
raggedjim's Avatar
Nice work, it always amazes me how much crap can be hiding in the nooks and crannys!
In western KY it's 55 with 43% humidity!
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 04-23-2024, 08:12 AM   #104
Chaparralman1974
Chaparralman1974's Avatar
Great work Scott! Tearing down the bed is more work than it looks. It took me all day to do mine doing the same thing you did.
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272
Chaparralman1974 is offline   Reply With Quote
Old 04-23-2024, 10:45 AM   #105
loudchevy
Active Member
loudchevy's Avatar
Rg
Clay
Thanks Gents.
Scott
2003 Tahoe Stock
