Old 04-28-2024, 08:38 AM   #7
toms68cst
toms68cst's Avatar
Re: Controlling fan with Terminator x Fan Control circuit
Thanks everyone. My friend went ahead and wired the fan through the sperate thermostat. He said it worked ok except for some short-cycling. He could see the temp display on the terminator drop a lot when the fan kicked on. I suggested that he try the Terminator control as it allows you to select switch on and switch off temps.
I suspect the problems mentioned by the radiator shop have more to do with wiring issues or misunderstandings than inherent problems with the ECU itself.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
