C10 Collector
Blazer rust tips (floor/rocker boxes)
This is kind of my thoughts, if you guys could help me understand the order of work I would appreciate it. I'm going to help my buddy fix his 1972 Blazer. Someone cut the rocker boxes off and never put back. Rockers are new but not done right. Rear floor is bad. Bedsides are good with small spots that are easily fixable. Tailgate is good, have rust free doors and fenders for it.
Replace: Rear Cargo Floor Rocker Boxes Rockers Unsure at this moment whether I will repair or bulk replace the front floor section. Any input on where to draw the line were replacing the whole thing is better than patching? My plan is to remove the rockers, bed sides, cargo floor, what's left of rocker boxes. What order should it go back together? I've done trucks and burbs but haven't messed with a rocker box before. Is the rocker box also the inner rocker? Thanks guys, Ryan
///Ryan 1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors 1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10 1967 Chevy LWB- 454 and patina 1971 Blazer - Rusty 1968 Crewcab project |
![]() Join Date: Jan 2007
Re: Blazer rust tips (floor/rocker boxes)
Before you change anything - you are going to have to do some pre-work to make sure you don't have issues down the road
The line that tells people to fix a panel or replace a panel - is all over the place. Some will say - ' keep as much original metal as possible' others will say that 'it's easier to just swap in a new panel' - it really comes down to your talent, patience and budget. I just swapped the entire back half of a blazer over a few weeks this past summer. It was very educational to see how these things are built and to note where rust is hiding. I took measurements from the old bedsides and then drilled equivalent holes in the new bedsides and put the top back on without any issues and the doors open/shut like they did before. Rocker box is not the same as inner rocker. The inner rocker is an extension of the cab floor and is usually rusted out if your floors/rockers are rusted. Going back together order that I used: support brackets for floor/rocker (torsion) boxes rear cargo floor wheel tubs bedsides outer rocker - this will take some time to adjust before the doors line up so don't finish weld this piece in until you confirm you are lined up. Get some pix of the truck and several on here can tell you what you are going up against. Here are a few helpful links to get you started. Door Frame Measurement links - check these before you cut anything - especially this post. Parts list I shared with another board member when he was building a blazer. Build posts have a wealth of knowledge and in the past few years, the aftermarket panels have surfaced making this job a bit easier. |
Truck was back together in 3 weeks with me doing the work on nights and weekends when I had the time.
It's all fixable depending on the interest and money. |
Thank you so much for this post.As soon as gmc Paul's gets the complete front floors in stock I will be replacing from the front floor back.Im a painter at a collision shop so I'm confident we would figure it out but this is EXTREMELY helpful.Thanks again
C10 Collector
Thanks for the reply. We just got the blazer stripped down to the body. The front frame horns are tweaked so I'll get it on the frame machine to pull that back over. The front floor is gone and someone torched the torsion boxes off. Inner Rockers are gone. Looking like a whole floor replacement front to back will be in order. I'm planning to cleco the weld seams to get it fitup and then disassemble back to where I can weld it up. Hoping to use my pro-spot as much as possible. If no one can tell I did any work that would be perfect.
Hoping to use my pro-spot as much as possible. If no one can tell I did any work that would be perfect.[/QUOTE]
I was staring at my blazer today figuring out where the pro spot will get to |
C10 Collector
So it gets worse. I took the body off the frame to address the chassis first and the frame is diamond, bent, cracked and hacked. So we are looking for another chassis at this point.
The good is between the factory frame drawings and what's left of this chassis I drafted up a body jig that I can mount to my chassis table to help align everything. After rust repair I will use the body jig to mount the body to my rotisserie. I also picked up a 71 Blazer for myself so I can do the metal work on it using the jig after the 72 is off it. As of right now we will be getting the chassis lined up and then ordering the replacement floors and patch panels. Since I don't have much left can you guys fill me in on what panels I need to purchase to do a complete floor. Do I need the cab to bed transition piece if I'm buying complete cab and bed floors? Thanks, Ryan
///Ryan 1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors 1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10 1967 Chevy LWB- 454 and patina 1971 Blazer - Rusty 1968 Crewcab project Last edited by Bagd72Chevy; 12-09-2020 at 09:44 AM. |
if you buy the complete floors - you will still likely need patches.
front floor might need the bucket seat braces for under the front floor rear cargo floor yes - you will need the step up plate as it doesn't come with the floors A-pillar - lower patches kick panels torsion boxes outer rockers get some pix of what is left and we can tell you more details. Good Luck! |
C10 Collector
Well we are getting started. Some parts were backordered but finally have it all. GMC Pauls is where I sourced everything. I took a spare chassis and set it up on my frame table so it is flat and square. For some reason one of the bed mount pairs is too short. Everything else lines up. Still thinking about how I'm going to line up the cowl.
///Ryan 1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors 1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10 1967 Chevy LWB- 454 and patina 1971 Blazer - Rusty 1968 Crewcab project Last edited by Bagd72Chevy; 08-23-2022 at 02:59 PM. |
Congrats on getting to this point - it's really not that bad once you get all the parts you need.
Some additional thoughts now that you are getting under way.
Looks like a great start. Good luck! *Added an 'after' picture of my project (same truck from my post above) for inspiration* Can you share more details on your issue with the 'bed mount' pairs being too short? |
C10 Collector
Yes, I have that panel sitting in place now. Need to punch the holes in it for the welds and then screw it together for fitup.
///Ryan 1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors 1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10 1967 Chevy LWB- 454 and patina 1971 Blazer - Rusty 1968 Crewcab project Last edited by Bagd72Chevy; 08-24-2022 at 02:31 PM. |
C10 Collector
I also have my other body that is in much better shape but still needs alot of work. But at least enough is there to look at how this one should go together.
Very cool! It took me 3 weeks to do the rear half and then 12 more months to do all the rest (floors, inner rockers, supports, a-pillar, torsion boxes, etc.) between waiting on parts, waiting for a free evening/weekend, etc.
I still have to fix the panel gaps and finish weld in the outer rockers to be complete. I'm not in a rush though since I can drive it again now. |
C10 Collector
The pro-spot is acting up so I jumped on it with the Roper Hole punch. Getting it all mocked up so I can fit everything.
![]() Also threw the bedsides on. They don't fit the floor real well so I'll have top dig into what the issues are later this week. My helper was doing a great job dropping the bolts in. ![]() ![]()
#15 |
![]() Join Date: May 2006
Looks good so far, nice way to start with all new sheet metal
#16 |
C10 Collector
Making some progress.
#17 |
Born Psycho
![]() Join Date: Feb 2001
you are doing an awesome job and your shop is over the top too.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
#18 |
X2 any progress photos good detail on the build thread
#19 |
C10 Collector
Finally getting back on this. Not much has changed. Struggling with alignment right now. Will update as I figure things out.
#20 |
In to see this thing come together!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#21 |
Post up a few pix of your alignment issues - could be a few common things...
| Bookmarks |
