05-02-2024, 05:03 PM | #1 |
Re: "52 3600/3100"
Small set back!!
So after installing glass and working out some cooling issues with the ls swap and some steering work with proper borgeson joints, lil barnwood bed install. I went for another 1/4 mile test drive. Everything working as it should on my way back up the street I am a happy camper. I go to just give it a little gas nothing wild but I must have spun the tires and SNAP. Something popped and I spun super hard into a grass embankment almost rolled and slid backwards into my neighbors yard. Thankfully I didn't have my kids with me because I hadn't installed my seat belts yet. After the initial assessment of the damage its looking like Ill need a new right rear axle and drum, a new radiator, short section of rear brake line, most likely changing the wheels. I did break some of my 4 link components but they look re usable. I wish I knew what caused initially but Ill never know. The sheet metal is all work able for what I need and I wasn't injured so its just a minor set back in the grand scheme of how bad it really could have been. |
05-02-2024, 05:05 PM | #2 |
Re: "52 3600/3100"
Glad you are alright! That sucks!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
05-02-2024, 05:19 PM | #3 |
Re: "52 3600/3100"
Yikes, glad it was only a 'test' drive and no one was hurt.
sounds like the 4 link let loose (weld?) and caused the damage?
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
05-03-2024, 07:05 AM | #4 |
Re: "52 3600/3100"
I'm thinking it was one of the welds on the pumpkin. I struggled to get one side STUCK really good, but I thought I had that issue resolved. This time around ill make sure I put the HEAT to it . Considering doing a parallel set up and ditching the triangulated rig all together so that's not a possibility for 2.0.
