SM465 Reverse Light Switch Gasket?
Does the reverse lamp switch need a gasket on the sm465? Im replacing the switch and it’s hard to tell if the old one had a gasket or it’s just old paint.
If it does need a gasket where can I get one? I can’t seem to locate one. |
![]() Join Date: Mar 2015
Re: SM465 Reverse Light Switch Gasket?
Just purchase a thin oil plug gasket and call it good.
![]() ![]() Join Date: Jul 2003
The specified part is GM 3929530.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. ![]() 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
Thanks for the part number. That lead me to this thread so I purchased Dorman 970827CD washers. Once they arrive i'll report back to confirm they fit.
https://67-72chevytrucks.com/vboard/...d.php?t=847229 |
I have several transmission switches with washers. If you are willing to post the dimensions I can see if what I have is the same size.
