05-03-2024, 08:54 PM | #26301 |
Re: Facebook Marketplace finds
https://www.facebook.com/marketplace...type=top_picks 1969 Chevrolet c10
$22,000 Listed 21 hours ago in Chehalis, WA |
05-03-2024, 09:04 PM | #26302 |
05-03-2024, 09:06 PM | #26303 |
https://www.facebook.com/marketplace...type=top_picks 1970 Chevrolet other
$2,500 Listed 9 hours ago in Missoula, MT About this vehicle Driven 100,000 miles Manual transmission Exterior color: Brown · Interior color: This vehicle is paid off Clean title This vehicle has no significant damage or problems. Seller's description 1970 3/4 ton Chevy long box (camper special). New clutch. Will run but needs some work. |
05-03-2024, 09:09 PM | #26304 |
1970 Chevy Pick-up
$6,000 Listed a week ago in Everett, WA Public meetup Details Condition Used - Good Has a 350 vortec motor and transmission! Runs Awesome! https://www.facebook.com/marketplace...type=top_picks |
05-03-2024, 09:46 PM | #26305 |
https://www.facebook.com/marketplace...6-621d7da824b2 1968 Chevrolet 2500 regular cab
$6,000 Listed 4 days ago in Washougal, WA |
05-03-2024, 09:50 PM | #26306 |
1968 to 1972 GM Trucks All original bucket seats With Consol $3,850 Listed 5 days ago in Lacey, WA Details Condition Used - Good If the Ad is up there still available And I do have the seatbelts That goes with it.Not looking to trade the Seats are in great condition minus the rust Stain And the small tear on the left side of the driver seat.If you think it’s too much money look somewhere else I don’t need your opinion on how much they’re worth . Thanks  Lacey, WA |
05-03-2024, 09:53 PM | #26307 |
https://www.facebook.com/marketplace...7-b14d747a34bd https://www.facebook.com/marketplace...7-b14d747a34bd
05-03-2024, 09:59 PM | #26308 |
https://www.facebook.com/marketplace...type=top_picks 1972 Chevrolet 2500 regular cab Long Bed
$3,500 Listed 4 hours ago in Portland, OR |
05-03-2024, 10:08 PM | #26309 |
No rust 77. 20K miles, original owner. But three on a tree 6 cyl., for $25K. https://www.facebook.com/marketplace...4-4def93b90b0f
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-03-2024 at 10:13 PM. |
05-04-2024, 02:38 AM | #26310 |
1972 Chevrolet blazer
$150,000 Listed 7 hours ago in Des Moines, IA About this vehicle Driven 300 miles Automatic transmission Exterior color: Brown · Interior color: Brown Fuel type: Gasoline Excellent condition Clean title This vehicle has no significant damage or problems. Seller's description 1972 Chevy Blazer Factory 2wd This is a fresh build with a lot of new parts that I'm sure I'm missing in the list. I'm more than happy to send you more pictures or video. We're asking $150,000 located near Des Moines Iowa. Engine/ Chassis: 5.3L LS (Steel Block) Cathedral port 862 heads New timing chain New Melling high flow oil pump New water pump Texas Speed Stage 4 cam New Chromoly push rods New single beehive valve springs Holley low profile oil pan and pickup tube Gibson Long tube headers double ceramic coated Fitech intake and 92mm throttle body Holley Terminator X Max ECU CVF Billet Pulley system with A/C Clayton Machine works polished coil covers Entropy Radiator with Dual 3,000 CFM fans CVF Black anodized Hood Hinges Willwood Master cylinder and booster All new dual exhaust with Magnaflow super 44 mufflers Custom made and bead rolled engine surround in satin brown Boyds Tank with in tank pump Russel braided fuel line and fittings All engine wiring tucked and hidden in black braided loom cover US MAG wheels 265/35R22 on the front and 285/35R22 on the rear Vehicle has been professionally dynode at Goblin Garage Transmission: 4l80E Circle D 3000 Stall converter New Drive shaft Brakes: Drilled and slotted CPP disc brakes on the front and rear Wilwood Master cylinder with new booster Wilwood Proportioning valve Polished brake line in the engine compartment Paint/Body: All new two tone paint job Extremely rust free body before we even started the restoration New 1967 body trim New grill and aluminum surround New bumpers front and back HID headlights Custom CNC’d aluminum fender emblem “LS1” New windshield All new Precision rubber seals everywhere Bed liner on the bottom side of the cab 2” lowering kit on the front 4 inch lowering kit on the rear Topper has been wrapped in tan German Convertible cloth material Interior: Custom interior by Sam’s Upholstery in Winterset Iowa Dakota Digital HDX gauge cluster Double din head unit with custom bezel wrapped in leather Back up camera Vintage Air A/C Flaming River Tilt steering column Leather wrapped Dash pad Leather visors with contrast stitching Tan German square weave carpet with leather trimmed edges Custom Leather seats with tan houndstooth inserts, tan piping and contrast stitching Custom rear side panels with two tone design and speakers mounted behind Custom leather tailgate cover Custom front door panels with two tone design with German square weave carpet on lower section Custom kick panels with pressed raised mesh Blocked off glove box with the Holley handheld and Bim sensor mounted Custom center console trimmed in leather with battery mounted inside Des Moines, IA Location is approximate https://www.facebook.com/marketplace...type=top_picks |
05-04-2024, 05:00 PM | #26311 |
https://www.facebook.com/marketplace...73868490%22%7D 1971 Chevrolet Suburban
$15,000 Listed 15 hours ago in Derby, KS Details Condition Used - Good 1971 Chevy suburban with a 454 and console air runs and drives good but needs some TLC. Would consider trades for good aluminum bass boat |
05-04-2024, 05:03 PM | #26312 |
https://www.facebook.com/marketplace...type=top_picks 1967 Chevrolet 3500 regular cab CST
$17,500 Listed 4 hours ago in Dover, TN |
05-04-2024, 05:04 PM | #26313 |
https://www.facebook.com/marketplace...type=top_picks 72 chevy p/u bed trailer
$600 · In stock Listed in Arma, KS Public meetup Door pickup Details Condition Used - Fair 1972 chevy p/u bed trailer, Pulls good, aluminum wheels, Bed could used again. $600 obo |
05-04-2024, 05:07 PM | #26314 |
967-72 C10 Custom Interior
$4,000 Listed a day ago in Wichita, KS Details Condition Used - like new For sale is a like new red custom interior for a 67-72 GM truck. This is not a kit! Included are original buddy bucket seats, headliner, visors, dash pad and door panels that are wrapped in premium soft red leather! The door panels are the 1972 style and are setup for power windows and locks. The upholster matched the original GM lines and gave it modern vehicle stitching. I don’t think you’ll find a better red interior out there! We will not separate the pieces. Wichita KS. $4000 https://www.facebook.com/marketplace...type=top_picks |
05-04-2024, 05:15 PM | #26315 |
https://www.facebook.com/marketplace...54432055%22%7D truck for sale
$10,000 Listed 2 hours ago in Arlington, TX Door pickup |
05-04-2024, 05:17 PM | #26316 |
https://www.facebook.com/marketplace...54432055%22%7D 1967 El Camino
$14,000$20,000 Listed 5 weeks ago in Bangs, TX Details Condition Used - Fair 1967 El Camino with small block 406 with power glide both rebuilt with 4000 stall converter with less than 200 miles on both. Has turbo 500 mufflers with headers. Has 2 hoods. Needs battery. Must sell. |
05-04-2024, 05:21 PM | #26317 |
https://www.facebook.com/marketplace...54432055%22%7D 72 Chevrolet
$6,000 Listed 2 weeks ago in Freeman, MO Details Condition Used - Good 6000 obo |
05-04-2024, 05:43 PM | #26318 |
https://www.facebook.com/marketplace...d-b112b45dc0f8 1967 Chevrolet short narrow bed bed C10 short narrow bed
$1,234 Listed 4 hours ago in Oklahoma City, OK |
05-04-2024, 05:44 PM | #26319 |
https://www.facebook.com/marketplace...d-b112b45dc0f8 1968 Chevrolet c10
$3,500 Listed 17 hours ago in Amarillo, TX |
05-04-2024, 05:49 PM | #26320 |
https://www.facebook.com/marketplace...d-b112b45dc0f8 https://www.facebook.com/marketplace...d-b112b45dc0f8
05-04-2024, 05:53 PM | #26321 |
https://www.facebook.com/marketplace...b-d922a44f9fc7 1967 Chevrolet c10
$6,000 Listed a day ago in Loveland, CO |
05-04-2024, 05:57 PM | #26322 |
1969 Chevrolet 2500 regular cab
$5,000 Listed 9 weeks ago in Grand Junction, CO https://www.facebook.com/marketplace...b-d922a44f9fc7 |
05-04-2024, 06:04 PM | #26323 |
https://www.facebook.com/marketplace...b-d922a44f9fc7 1967 Chevrolet k-10 4x4
$12,000 Listed 13 weeks ago in St Onge, SD |
05-04-2024, 06:16 PM | #26324 |
https://www.facebook.com/marketplace...b-d922a44f9fc7 1969 Chevrolet 2500 regular cab
$3,500 Listed 11 weeks ago in Logan, UT |
05-04-2024, 06:18 PM | #26325 |
https://www.facebook.com/marketplace...type=top_picks 1970 GMC 2500 regular cab Long Bed
$6,000 Listed a week ago in West Valley City, UT |
