Old 01-21-2009, 02:46 PM   #26
hilandr452
hilandr452's Avatar
Re: engine assembly code
OK, what you're saying is that it just doesn't come on trucks? Don't flame me, I'm just trying to clarify.
Dan Smith
Colorado Springs, CO
71 GMC Custom Camper "Longhorn" 454, TH400
73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny
"DON'T TREAD ON ME !!!"
My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442
hilandr452 is offline   Reply With Quote
Old 01-21-2009, 02:55 PM   #27
sameyrasmea72
sameyrasmea72's Avatar
I am just saying the info you already have is just about all the info you are going to get. There is not a for sure 100% guarentee way to tell if a 67-72 chevy truck has the original engine or not because THERE IS NO VIN # ANYWHERE ON A TRUCK MOTOR.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 01-21-2009, 03:04 PM   #28
leddzepp
Moderator
leddzepp's Avatar
Originally Posted by sameyrasmea72 View Post
There is no, repeat no vin # stamped on a truck motor period.
x2
Old 01-21-2009, 03:57 PM   #29
hilandr452
hilandr452's Avatar
I got it, I was simply trying to clarify. No need to shout, man.
Dan Smith
Old 01-21-2009, 04:05 PM   #30
sameyrasmea72
I did not mean to shout. I was just trying to get to the point that Stope and Clay and others made earlier in the thread.
72 Cheyenne Super
Old 01-21-2009, 04:07 PM   #31
hilandr452
hilandr452's Avatar
Thanks for the info, I'm satisfied this is the original motor.
Dan
Dan Smith
Old 01-21-2009, 04:10 PM   #32
sameyrasmea72
I was going to say that I would be very confident that your engine is the original one. Too many things line up for it not to be.
72 Cheyenne Super
Old 01-21-2009, 05:41 PM   #33
hilandr452
hilandr452's Avatar
This truck was a nice find. I've been dreaming about one of these since I was a kid.
Dan Smith
Old 09-10-2009, 05:17 PM   #34
DANTIP
DANTIP's Avatar
FYI,
My 72 engine code is T1221TLM and my truck was assembled January 5, 1972 (from Build-Sheet). The "T" stands for Tonowanda, the 1221 stands for December (12), 21st (21) and the TLM is the correct code for a 72 402 with A/T and smog pump. By the way, my Protect-o-plate has the T1221TLM stamped in it. That's as close as you get to "Numbers-Matching" in these trucks.
Did your look for the Protect-o-plate?
DANTIP is offline   Reply With Quote
Old 09-10-2009, 10:51 PM   #35
roger0080
You would need the protect-o-plate that came with the truck to determine that.
Chevrolet protect-o-plates have the engine number stamped on the POP to match the engine. But it seems that GMC would just say the engine size like "400" for a 396/400/402 and not have the stamped engine number on it on the POP. So even if you had the POP for it, it wouldn't have the engine number on it. This is all from memory so it may not be 100% correct.
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
Old 09-11-2009, 07:58 PM   #36
327-C10
Originally Posted by hilandr452 View Post
Clearly, there is no number located on this deck. Here's a picture.
I think there are other locations on the engine for this information, so I'm going to see what I can figure out. Any info or advice would be helpful.
Dan
Having 30 year of re building engine for the corvette guys I would say that is not a re-stamped block. Normally the broaching marks after decking a block (only 2 reasons to are to confirm center of crank to deck height or to lose original stamping) are circular. your broach marks are straight. To me that original.
Good luck with what every you do.
327-C10 is offline   Reply With Quote
Old 05-04-2024, 08:38 AM   #37
gmc 2500 4x4
Old post, would someone know what the kx is for T0927TKX
gmc 2500 4x4 is offline   Reply With Quote
Old 05-04-2024, 09:41 AM   #38
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: engine assembly code
TKX 1972 Truck 402CID 210NHP TH400 L-47 Series 20, 30
T- Tonawanda engine assembly plant
09=September
27=day
Old 05-04-2024, 09:48 AM   #39
gmc 2500 4x4
What letters make it a72.?
Old 05-04-2024, 09:54 AM   #40
1970cstblazer
The TKX code is a 1972 model year code assembled 9/27/71.
Old 05-04-2024, 09:58 AM   #41
gmc 2500 4x4
Thanx, just trying to get a manufacture date for a valve cover decal that is being reproduced on here
