Old 05-13-2024, 03:58 AM   #1
BlouDon
BlouDon's Avatar
Recommended carb for std 350ci v8?
I'm not interested in serious horsepower. I'm interested in max torque between idle and 3000rpm.
My engine is fitted with a spread bore intake manifold.
What would you recommend?
Best regards, Philip
Chev: '70 C10 (350 V8 / 700R4 ) & '59 Apache ( 235, 3-sp )
Jensen Interceptor '74: Mopar 440(EFI'ed) / 4L60e
Jaguar: '72 E-type Coupe V12 & '74 E-type V12 Convertible & '80 XJS V12
BlouDon is offline   Reply With Quote
Old 05-13-2024, 07:52 AM   #2
tim_mc
tim_mc's Avatar
Re: Recommended carb for std 350ci v8?
Lots of opinions on the way. I love my Edelbrock AVS2.
https://www.edelbrock.com/avs2-carburetors
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
Old 05-13-2024, 07:59 AM   #3
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Recommended carb for std 350ci v8?
A properly built Q-Jet is the only way to fly for everything but a serious HP drag only special.
At minimum the primary and secondary throttle shafts must be bushed, and the lower well plugs sealed, and the whole carb checked for warping.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 05-13-2024, 01:09 PM   #4
truckster
truckster's Avatar
Another vote for the Quadrajet. They're great carbs.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 05-13-2024, 01:23 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I'm still running the original Q-jet, though it's been rebuilt a couple times.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 05-13-2024, 01:48 PM   #6
Getter-Done
Getter-Done's Avatar
Quadra-jet is my vote also.
84 Chevy K-20
Old 05-13-2024, 02:54 PM   #7
BROWN 70
BROWN 70's Avatar
x 5 for the q jet. its all mine has ever had. great carb. BROWN 70
BROWN 70 is offline   Reply With Quote
Old 05-13-2024, 02:55 PM   #8
Rust_never_sleeps
Rust_never_sleeps's Avatar
Original Q-jet works great. Not sure it's max torque though
1970 C10 Custom longbed 350/350
Rust_never_sleeps is offline   Reply With Quote
Old 05-13-2024, 03:30 PM   #9
truckster
truckster's Avatar
The small primaries are designed to favor torque. The large secondaries only kick in when there's enough vacuum to pull the door open.
Old 05-13-2024, 05:14 PM   #10
RustyPile
RustyPile's Avatar
Stock engine, or one that is only midly modified??? Already has spread bore manifold.. Qjet is only choice.. Consider nothing else.
RustyPile is offline   Reply With Quote
Old 05-13-2024, 05:28 PM   #11
Steeveedee
Who Changed This?
Steeveedee's Avatar
As for performance, Cliff Ruggles campaigns a real fast Pontiac drag car with a q-jet on it.
~Steven
Simi Valley, CA
Old 05-14-2024, 12:36 PM   #12
MARKDTN
I'm an EFI guy but if you have to have a carb on a stock engine a Q-jet is hard to beat. My next choice would be a spread bore Holley.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 05-14-2024, 01:53 PM   #13
MikeB
MikeB's Avatar
I'm surprised that some company hasn't brought back the Q-jet. Edelbrock did for a while but quit. I'm not sure why.
I had a couple stock ones over the years on 327s. Great carb for fuel mileage, with performance when you needed it.
Someone above mentioned a Holley Q-jet replacement (0-80555C). They also have a 0-9895 that can be used on emission controlled engines. But those things are expensive!
I also see that Holley has a Sniper EFI model for Q-Jet manifolds.
Mike
1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 05-14-2024, 01:56 PM   #14
72SB
tail wagging the dog on OP's 350 is the spread bore manifold so Q jet
Yeah a square bore adapter and Edelbrock could work but if getting an Eddy carb, get a Edelbrock dual plane manifold
72SB is offline   Reply With Quote
Old 05-14-2024, 02:16 PM   #15
Rust_never_sleeps
Quadrajets are not one-size-fits-most, btw. You need the right one with the right guts in it for the 350 SBC.
Can't guarantee you'll love the q-jet, but if you're putting a square peg in a round hole, you're bound to hate it.
Old 05-14-2024, 02:25 PM   #16
I have had Edelbrock 1403, 1405, and 1406 and Holley 4160 carbs on my 350's. I have really liked the 1406 (600 CFM) the best and that is what I am currently running. Qjets are fine if you can get them tuned right they do pretty well. I never had any luck with Qjets and its hard enough to find someone who can work/tune a carb let alone a QJet one.
Old 05-14-2024, 04:49 PM   #17
68 C10 Driver
I have had Edelbrock 1403, 1405, and 1406 and Holley 4160 carbs on my 350's. I have really liked the 1406 (600 CFM) the best and that is what I am currently running...
I plan on putting a Edelbrock 1406 on my truck (350 cu/in) when I get to that stage. I already bought the carb, hopefully I will get the frame done soon and get the cab back on it. Then it will be time to install a motor.
68 C10 Driver is offline   Reply With Quote
Old 05-14-2024, 06:15 PM   #18
72SB
I use 1406 on all my SBC and ford motors. For camed small blocks like any carb, you can tune them using the 1406 specific Edelbrock tune kit. Jets, metering rods and step up springs. Very easy carbs to work on and for me perform well
Old 05-15-2024, 04:13 PM   #19
wrangler94
I recently bought a quadrajet core that's proper for my 70 chevy, and rebuilt it with a kit from Cliff Ruggles and all, and now I'm getting no fuel, or sporadic fuel anyway, so I'm gonna go through it one more time to see if I messed something up.
If that doesn't work, and I buy the 1406 Edelbrock, do I need adapter plates or anything like that? Custom stuff to work with transmission, throttle linkage, etc? Just planning ahead in case going through this carb a second time doesn't reveal anything.
1970 Chevy Custom 10
1970 truck project
wrangler94 is offline   Reply With Quote
Old 05-15-2024, 06:06 PM   #20
slikside
slikside's Avatar
Did you also buy his book on rebuilding the Q-Jet, and follow it closely?
Maybe you have more experience with these carbs than I did when I rebuilt mine(I had zero). But I followed his book diligently, and it paid off. Worked perfectly, and still does some 10+ years later.
Cliff has spent a looong time working on these carbs, and all that knowledge is poured into his book. Way more than you might get from, say, the instructions with a kit or…
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor.
slikside is offline   Reply With Quote
Old 05-15-2024, 08:53 PM   #21
chevmn
Another vote for q-jet, but make sure of what you get, as there are different variations. In addition, I always replace the synthetic type floats in favor of a brass float. Many fight and toss perfectly fine carbs simply due to a heavy or sunk float, and I nearly did that same thing many years ago until someone familiar with them actually weighed the float, and we replaced with brass, and it was in the carb until I got rid of the truck years later. I just rebuilt one and due to the truck running propane, the primary throttle bores were worn out. Drill and bushing fixed and it runs fine.
chevmn is offline   Reply With Quote
Old 05-16-2024, 02:30 AM   #22
Rust_never_sleeps
<snip>
Cliff runs and monitors a forum on q-jets, you'll get help there:
https://cliffshighperformance.com/si...m/index.php#c2
Old 05-16-2024, 03:09 AM   #23
mr48chev
mr48chev's Avatar
This is an excellent point. If you have the correct carb for the engine you have now I wouldn't swap it for a bigger Q jet, I would get the correct kit for it and rebuild it with a couple of small mods that don't change performance but solve a couple of small issues.
I think I got my last kit from Cliff's high performance Quadrajet as I got the bottom plug kit he sells to fix the bottom plug leak.
https://cliffshighperformance.com/ The gaskets and parts are all fresh and you aren't getting a kit that was sitting on a shelf in a warehouse for five years or longer.
The other thing besides that is that the the throttle shaft holes wear and get loose and there are tools and kits to replace them.
My ongoing truck projects:
Old 05-16-2024, 05:47 PM   #24
wrangler94
Yes I used his kit and his book. I'm aware of the forum too. ONce I tear into it again and know more I'll post there and ask, if I don't find something dumb I missed.
1970 truck project
Old 05-17-2024, 07:15 AM   #25
1970cstblazer
This whole "bigger Q-Jet" talk is really nonsense. That is the beauty of the Q-Jet. They were used on 6 cylinders through 500 Cadillacs. The secondary air valves only open enough to satisfy engine demands. Yes there were 800 CFM units, mostly found 1975-up. The run of the mill 750 CFM Q-Jet will work on almost any engine these trucks will see. The main things to keep in mind are air bleed sizing, well plug sealing, idle tubes, jet/metering rod sizing, proper float level, a good matched straight core to begin with, and bushed front and rear throttle shafts.
