Old 05-17-2024, 02:09 PM   #1
ScottH
ScottH's Avatar
Another fuel gauge question
So I'm working on a 63 c10 attempting to get it back on the road. Having several wiring issues but this issue is with the fuel gauge. I recently installed a tank & sending unit I picked up used. The sending unit looked brand new as well as the tank.
What is happening is with the tank empty & I turn the ignition on, the fuel gauge goes to just under a half full & stays there. If I disconnect the power wire at the sending unit, the gauge goes to full. If I ground the power wire it goes to just under half full.
The tank & sending unit are installed & I had some issues with installing the sending unit so would prefer not to take the unit out of the tank unless absolutely necessary. Also I tested the unit with a multi-meter & it reads 0 as tank is empty.
Looking for any info or suggestions that can help me figure out where I should do next to figure out the issue. Any info would be most appreciated.
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 05-17-2024, 05:06 PM   #2
ACK
ACK's Avatar
Re: Another fuel gauge question
Sounds like the classic fuel gauge OHM issue. The forum has lots of info about this, search OHM and you'll get plenty of returns.
My truck ain't dead, it just smells funny.
ACK is offline   Reply With Quote
Old 05-17-2024, 06:39 PM   #3
ScottH
ScottH's Avatar
Turned out 2 b a stuck gauge needle.
Old 05-17-2024, 08:54 PM   #4
SkinnyG
SkinnyG's Avatar
Yay!
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
