Old 05-14-2024, 11:13 PM   #1
Nick_R_23
Nick_R_23's Avatar
1978 Chevy C10 Custom Deluxe
Yup, not much more than a week after picking up my ‘80 C10, I also found this one on marketplace just up the road from me, not even two miles away! It’s rough, but fairly complete, and best of all was only $200! I wasn’t going to pass on a 2wd shortbed for that price.
It has been sitting for a while, but apparently it drove to where it was parked. I’m not sure I believe that, but it does appear intact enough under the hood that it’s possible.
This is how I found it.
Pulled it out of its hole!
Surprisingly, all the tires held air but one (couldn’t get the bead to seat again), so I swapped it with a spare I had.
The core support identifies the truck as a 305 unit, but apparantly it’s been swapped out for a straight 6 sometime in its life, backed by a TH350.
Loaded on the trailer!
The GVWR is 5300lbs, so it’s not a Big 10, but it does still have a 12 bolt rear axle and the thicker spring pack.
She’s home, time to clean her up!
Old 05-15-2024, 01:43 PM   #2
straight6chevyguy
straight6chevyguy's Avatar
Re: 1978 Chevy C10 Custom Deluxe
Wow great deal, do you have any plans for it?
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1998 chevy c1500 4.3L 5speed (My current driver)
2002 Chevy s10 4.3L auto 4x4
1971 mercury monterey wagon 400 auto
To many projects!
straight6chevyguy is offline   Reply With Quote
Old 05-15-2024, 04:01 PM   #3
Nick_R_23
Nick_R_23's Avatar
Probably nothing extreme, clean it up, straighten it out, get it running and drive it!
Old 05-15-2024, 07:06 PM   #4
rodstored-72
chevy truck fan
rodstored-72's Avatar
nice I guess pretty good shape considering it's home (alaska)? I like your plan for it, keep us posted
rodstored-72 is offline   Reply With Quote
Old 05-15-2024, 08:20 PM   #5
Nick_R_23
Nick_R_23's Avatar
It’s actually far better than it look, the pictures kind of don’t do it justice. The paint and dirt and crooked bumpers makes it look absolutely terrible, but I think once it has a single color of paint on it, it’ll look a lot better.
Old 05-15-2024, 11:30 PM   #6
straight6chevyguy
Sounds like a good plan
To many projects!
Old 05-18-2024, 03:01 AM   #7
Nick_R_23
Nick_R_23's Avatar
I cleaned out the bed this weekend, to the tune of an $85 dump run. They sure had the back packed FULL. This wasn’t even all of it!
Also tinkered on the engine a bit. It was gently seized, but I tightened the belts and let it soak with a mix of ATF and diesel in the cylinders for about 30 minutes, and rocked the fan back and forth until it turned.
Added battery power, and jumped the solenoid with a screwdriver, and it cranks over really well!
Picked up some basic parts to get things started. Oil and filter, plugs, wires, cap, rotor, ignition coil, carb rebuild kit, waterpump, upper radiator hose, turn signal switch, ignition slider switch, and key switch.
Old 05-18-2024, 12:18 PM   #8
straight6chevyguy
I noticed that your engine has the integrated head so must be a period correct engine.
I'm just curious if it is the 2 barrel or single barrel setup kinda hard to tell from the pics though judging by the exhaust piping it might be 2 barrel. Anyway just curious I'm a straight 6 enthusiast lol.
To many projects!
Old 05-18-2024, 12:46 PM   #9
Nick_R_23
Nick_R_23's Avatar
It’s a 1975 engine according to the numbers, and I’m 99% sure that it has the 1BBL carb, at least that’s what rebuild kit I bought, lol. I’ll be diving into it a little more in the next day or so.
Old 05-18-2024, 07:20 PM   #10
straight6chevyguy
Ok the two barrels didn't come in till around 1978 or so.
I looked again at your pics I don't think that was the exhaust pipe I was seeing so never mind lol.
To many projects!
Old 05-29-2024, 11:31 AM   #11
Nick_R_23
Nick_R_23's Avatar
The rest of my tune up parts showed up last night! Gave her a new cap, rotor, plugs, wires, and have a new waterpump, thermostat, and radiator hoses ready to go on as well.
I did a quick wiring job to put power to the distributor, and she fired right up and idled!
Old 05-29-2024, 01:05 PM   #12
Nick_R_23
Nick_R_23's Avatar
https://youtu.be/3PxQMFEpJ9I
Old 05-29-2024, 03:37 PM   #13
straight6chevyguy
Sweet!
To many projects!
Old 05-29-2024, 04:54 PM   #14
rodstored-72
chevy truck fan
very cool!!!! nice job!
Old 06-04-2024, 04:04 PM   #15
Nick_R_23
Nick_R_23's Avatar
I found this fun little setback this weekend
It’s already broke. Let’s give it a shot lol
Old 06-04-2024, 07:10 PM   #16
straight6chevyguy
Ouch, bummer . Hopefully the glue will fix it if not that's pretty disappointing. I've heard of that happening but had never seen it myself
To many projects!
Old 06-04-2024, 07:56 PM   #17
Nick_R_23
Nick_R_23's Avatar
If not, no big loss. I’ll yard it out of there and put a V8 back in.
Old Today, 02:28 AM   #18
Nick_R_23
Nick_R_23's Avatar
Picked up a new radiator today! For some reason, I had to order an 80+ model year because it was a 19” tall radiator and the only options for 1978 were 17”. This also meant that I needed a matching upper hose because apparently the inlet size changed from the earlier years.
I also scored a grille for $60! It’s not correct, but does clean the front up a lot.
