Junior Member
![]() Join Date: Apr 2024
Project Noah
Might as well start a build thread for the old 71. I bought the truck from a customer of ours. We have worked on her mower several times and would always see this truck parked behind a tractor. I finally asked her about it and she let me look at it. She offered to sell it and I think I said I’d by it before she ever said a price. She told me I could call the truck Noah. I don’t know why she said that name, but it felt fitting so that’s that. These pics are the day she let me look at it.
Junior Member
Re: Project Noah
Here’s some after getting it to the shop and pressure washing her off
![]() Join Date: Jan 2007
Re: Project Noah
Subscribed!!
I live in California, but identify as a Texan ![]() "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
![]() Join Date: Dec 2009
Re: Project Noah
X2 Subscribed
Re: Project Noah
I really like the Back Bumper.
Junior Member
Re: Project Noah
I got it to the shop and installed a new set of point and poured some fuel down the carb and she fired right up. I checked all the fluids and rigged a gas can to fuel her and she cranks right up and purrs like a kitten. So knowing she would run, I went to the fuel tank and pulled it thinking I could clean it. Not a chance! It was half fuel of 20 year old fuel and rust. So that gets me to where I am. I think I’ve ordered the wrong fuel tank so I got to swap that out. Here’s some random pics of the interior I took this afternoon.
Junior Member
Re: Project Noah
More random pics
Re: Project Noah
Those rockers are solid! Interior and floor mat looks like it should clean up real nice too.
I’m guessing 116k on the mileage.
Junior Member
Re: Project Noah
I tried to get some pics of the paint so yall could tell me what I needed to do about it. It’s got white paint scuff marks all over it. And some light rust in spots. Need y’all’s opinions. I’m also hoping those front bumper brackets are bent and nothing serious.
Junior Member
Re: Project Noah
That rear bumper is a beast. It was definitely a farm truck. The woman I bought it from said her father-in-law bought it new. Noticed on the tag in the glove box it said rear step bumper and heavy rear springs. He was definitely using the truck. She’s also got an 81 C30 2wd in great shape I want to go buy. Lol
Re: Project Noah
Sweet find! It's my favorite color.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1978 chevy c20 350 4speed 1998 chevy c1500 4.3L 5speed 2002 Chevy s10 4.3L auto 4x4 Plus a Mercury & some Fords... To many projects! |
Junior Member
Re: Project Noah
Re: Project Noah
Not sure how familiar you are with these trucks. Key is keeping it from rusting (or rusting further).
One of the first things I do as part of clean-up is clear all the "weep" holes. They are everywhere on these trucks and may be clogged by mud or animal nests. Some of them are listed below. vacuum and/or water hose are the tools -bottom front of front fender (may find some tools or other stored there) -rear brace of front fender (if you have paint bubbling on the outside) -cowl and down the A pillar at the vent (remove wipers and cowl panel; vacuum the upper cowl area. Snake a small vacuum hose down the A pillar; go inside and remove the vent assembly and vacuum) run water from the top of the cowl until it runs clear out the bottom at the A pillar. -rear cab corner -bottom of doors (take off inner panel and vacuum it out, ensure drain holes are open) -rocker panels (spray a water hose up into the drain holes until it runs clear out the other one) |
Junior Member
Re: Project Noah
Thanks cj for the heads up. I’ve already cleaned the rear cab corners. They were solid dirt. There’s maybe 6 or so tiny pin holes in the cab corners that I tried to get a picture of. How would yall go about repairing those?
#15 |
Re: Project Noah
I have a 67 and 68, both came with enlarged weep holes...lol (rusted).
The tell tail weep hole will be the forward corner of the pass side front fender. Acid and rust usually always destroy that little well area. If yours is intact, clean it (first), clean it thoroughly and put some of that rust neutralizer down in there, then some paint. Do the same with rear cab corners and any other accessible wells... Just the fact that your seat is original and in new condition is crazy!!! Being a 71 it can only have disc brakes in front. That is a huge deal, no conversion needed. In good working order these brakes stop as good as any newer pickup on the road!!! I, too like the "diving board" rear bumper, best part is that it's a factory installed!!! Those hub caps look like thay would clean up nice after glass bead blasting, if not those are advertised for sale, here, all the time, they are plentiful and generally not expensive. I wonder if a 292 with an automatic trans is very common...I really like that setup!!! That looks like a great candidate to clean up and stay original. I favor that, as do many here, or clean it up and touch up the paint where needed. Carry on!!! Have fun!!! |
#16 |
Junior Member
Re: Project Noah
You mean under the battery?
#17 |
Re: Project Noah
Very cool truck! I love that color. I had a dark green truck with paint in similar condition. If you hit it with CLR and #000 steel wool that will clean up most of the surface rust and white marks. Then buff it with a good rotary wheel and your favorite polish. My paint shined like new again, minus all the faded areas of course!
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
#18 | |
Junior Member
Re: Project Noah
#19 |
Active Member
![]() Join Date: Oct 2012
Re: Project Noah
Nice score on the 71! I'll be following along on the progress.
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
#20 |
Re: Project Noah
Yes... That's typically rusty on even the best trucks due to battery acid leakage.
#21 |
Re: Project Noah
On my 67, the pickup is in pretty good shape. The hole in the bottom of the RH fender is big enough to stick your hand through. There was a complete front clip. for sale here, way back. I agreed to buy it, drove to Olathe to get it. It was as pristine, as advertised. That well in the fender didn't even have surface rust on it!!!! Thanks, again, Mike!!!
#22 |
Re: Project Noah
What an awesome-looking project! Other than getting is running, I'd don't know if I'd change much!
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
#23 |
Junior Member
Re: Project Noah
Other than the tires, I’m going to try to keep everything original
Edited: and the exhaust. The tail pipe is completely rusted away from the muffler and hanging by some wire Last edited by Auston; 05-21-2024 at 05:28 PM. Reason: Added text |
#24 |
Re: Project Noah
Very cool!
#25 | |
Re: Project Noah
