05-22-2024, 10:34 AM | #1 |
rear axle shock tabs/brackets 4x4 - where to buy?
I have a 70 K5 blazer that has a mystery axle in the rear. It is a 12 bolt, 6 lug axle with spring perches but no shock mounting brackets.
Someone may have added perches to a 2wd bracket at some point? Not sure. Gear ratio's match front to back so it's getting used. The front axle had a legible BOM number, it's a 1980 K20 dana 44 with a 6 lug pattern. Maybe the rear is also out of this truck, though I would think the shock brackets would be on this. Are they any factory style brackets I can buy to weld onto the axle tube? Tried searching but I just come up with the 2wd brackets that attach to the U bolts.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" |
05-22-2024, 11:07 AM | #2 |
Re: rear axle shock tabs/brackets 4x4 - where to buy?
White K20 |
05-22-2024, 02:22 PM | #3 |
I've bought from Barnes and RuffStuff and WFO Concepts, all good Vendors
https://www.ruffstuffspecialties.com/SHOCK.html https://www.wfoconcepts.com/c-139308...bs-mounts.html
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
05-22-2024, 04:12 PM | #4 |
Born Psycho
if your front axle is out of an 80 K20, it would be a GM 10 bolt with 8 lugs unless someone swapped the 6 lug stuff over to it. i believe the last year for dana 44s was 76 then they switched over to the corporate 10 bolt.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
05-22-2024, 05:12 PM | #5 |
Check the mounting bolt sleeve of your shock should be 1-1/2" like these brackets
https://www.amazon.com/RuffStuff-Spe...n2dvfli9lrj86g https://www.amazon.com/dp/B01MT2XON7...9ocXBfc2hhcmVk |
05-22-2024, 11:11 PM | #6 |
All about them K’s
I used the tabs from ruff stuff on my K20 and have been more than pleased with them.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
05-23-2024, 09:21 AM | #7 |
Thanks for the info. I’ll get some ordered up.
05-23-2024, 01:49 PM | #8 | |
05-24-2024, 10:20 AM | #9 | |
Worked perfectly! |
05-24-2024, 06:02 PM | #10 | |
05-24-2024, 06:04 PM | #11 |
I looked up the BOM and it came back as an 1980 dana44 k20. I don’t think all of the 3/4 ton was 8 lug at that point but who knows. That’s what it came back with and it’s 6 lug. It’s definitely a Dana 44 axle.
