Re: Fashionable Fever! - 1969 Chevy C10 Build
Holy smokes, I can't seem to catch a break. Was getting the last of the house interior projects wrapped up and then March of 2023, ended up having ice dams which caused leaks in the master bed and the living room. Had to redo parts of ceiling, walls, insulation, etc. Worst part of it all was having to rip apart and redo the work I just did a couple years prior. Things didn't get done as quick, plus after getting home from working construction all day, makes it hard to get ambitious. Have a few things left to get done, but the weather is nice, so I'd rather be outside.
Finally pulled the trigger on a rear disc brake kit from Baer. Put most of it together. Didn't install pads or loctite yet. Want to make sure the park brake cable and brake lines will work with the orientation of the caliper first. |
![]() Join Date: Sep 2015
Good to see you back at it. I was wondering what happened to you there. Sounds like you've been busy.
