Old 05-26-2024, 07:49 PM   #1
damnyankee36
damnyankee36's Avatar
C10 Carpet Too Short
I just tried to install the carpet, (ACC), in the 68 and it's too short. It doesn't go all the way to the back wall. I noticed the tag on the box says it's for a cab-mounted gas tank. The description in the Classic Parts catalog doesn't say anything about it being for a cab tank.
I went to ACC and they only show a full-length carpet for a large hump floor.
Does anybody know where I can get a full-length carpet?
1966 C10 Custom Cab Restomod (Sold)
1969 Camaro Z/28 (Keeper)
Current Build: 1968 C10 (Semi-Factory Restoration)
1983 Camaro Z/28 (Next in line, Keeper)
1951 3100 (2nd in line)
damnyankee36 is offline   Reply With Quote
Old 05-26-2024, 07:52 PM   #2
damnyankee36
Re: C10 Carpet Too Short
Update. I now see ACC considers an original floor with a TH400 a high hump. I thought high/large humps were for 4-speed trucks!
Old 05-26-2024, 09:13 PM   #3
68Gold/white
High humps were also for pickups with the TH400 transmission.
68Gold/white is offline   Reply With Quote
Old 05-27-2024, 01:40 AM   #4
68bowtie
68bowtie's Avatar
You got it, high hump was for manuals, 4wds, and bbc/autos.
Not quite following why the carpet wouldn’t go all the way to the tank. It’s possible they have some that just go to barely under the seat?
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
Old 05-27-2024, 09:04 AM   #5
damnyankee36
Thanks, guys.
I discovered that ACC has a few combinations with humps, with or without tanks, auto trans, TH400 trans. Classic Parts only has two carpets; small or large hump. No mention of with or without tank. Figures...
I found the part# I need. I'll probably go with Amazon. Less than $200 free shipping compared to going directly through ACC for $300.
Old 05-27-2024, 09:12 AM   #6
68bowtie
68bowtie's Avatar
Check rockauto too, they carry thr same options.
Old 05-27-2024, 09:21 AM   #7
bowtie72
bowtie72's Avatar
I have ordered two from Rock Auto. One truck is a bb/400 high hump, one sbc/350. Both were short. If you order the gas tank cover carpet it will cover the rest of the floor.
1968 SWB "Little White Truck"
1972 LWB LS 4l80 "Plain Jane!!"
bowtie72 is offline   Reply With Quote
Old 05-27-2024, 10:20 AM   #8
damnyankee36
Cool, even cheaper. $172 total. I'll be getting #17901. TH400 and covers the entire floor.
Old 05-27-2024, 11:27 AM   #9
72c20customcamper
72c20customcamper's Avatar
Odd I ordered from Rockauto also the one I put in my 68 actually was climbing up the tank I ended up loosening the tank and tucking the carpet under it . 1968 with 4speed so I ordered the high hump .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 05-27-2024, 02:43 PM   #10
Richard
Got mine from Summit https://www.summitracing.com/parts/auc-carpet
Matching floor mats https://www.summitracing.com/parts/auc-mat
Richard
Old 05-27-2024, 03:19 PM   #11
72c20customcamper
Originally Posted by Richard View Post
I just looked mine up at summit unless you do the price match Summit is a lot more money than the exact same carpet set from Rockauto even after shipping. And if you go to retailmenot you can get a 5% discount code .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-02-2024, 02:02 AM   #12
Hatzman
Hatzman's Avatar
Originally Posted by damnyankee36 View Post
Thanks, guys.
Can you post the part #?
Steve
___________________________________
http://67-72chevytrucks.com/vboard/s...d.php?t=618848
Hatzman is offline   Reply With Quote
Old 06-02-2024, 09:27 AM   #13
damnyankee36
17901
EDIT:
Steve, beware. Wrong part number, at least for me...
See below.
Old 06-02-2024, 01:36 PM   #14
damnyankee36
You have got to be F**KING KIDDING ME!
Even though this truck originally came with a 400, if this carpet is any indication, I obviously have a small hump! The first carpet that was too short fit way better. Now that I have done a little more research it seems all high humps were bolt-in?
I guess 3rd time's a charm. I'm going to order the "regular" auto transmission option.
BTW, I have no reason to believe this is not an original TH400 truck. The truck was basically unmolested. The kickdown harness and switch are still present. Nothing else looks to be modified for it to be a 350 to 400 swap. Everything looks like it belongs. The SPID says "M49" but, apparently, the same code is used for 350 and 400's.
Now to B*tch at Summit for telling me the hood nose molding I just got in is a Goodmark manufacturer. They either don't know they are talking about or they switched manufacturers.
It's a Corvex piece. Just like the first Corvex piece I tried to install, it's not angled enough to match the hood. It just kinks in the middle when I try to form it. Any ideas?
I am so sick of this...
Old 06-03-2024, 02:08 PM   #15
70STOVEBOLT
70STOVEBOLT's Avatar
All high humps are bolt-in. You have a low hump.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 06-06-2024, 09:47 PM   #16
dmjlambert
dmjlambert's Avatar
For some reason carpet vendors sell carpet as TH400 transmission means high hump. It does not. I don't think there's a chance any carpet vendor will correct this, it is just the way it is. I bought a TH400 carpet for my low hump truck with a TH400. I fixed it by putting a 2x10 board on the hump, making it a high hump. I like it and may just buy high hump carpet again when it comes time to buy new carpet again. I set an organizer/drink holder on it, and screwed the mount for my fire extinguisher to the passenger side of it using wood screws through the carpet.
dmjlambert is online now   Reply With Quote
Old 06-07-2024, 04:36 PM   #17
damnyankee36
I thought about building up the tunnel to match the carpet but I didn't want to "make it work".
