suspension help
Anybody know if there is a frontend rebuild kit out there with polygraphite that is not 500 dollars or some outrageous price for a 72 2wd?
http://www.perfomancesuspension.com
C-10 1971-72 Disc Brakes $379.95 includes Chevy 2 Wheel Drive Kits contain: Upper & Lower Ball Joints Inner & Outer Tie Rod Ends Idler Arm Complete Upper & Lower Shaft Assemblies (Where Applicable) Graphite Impregnated Polyurethane Bushings* Upper & Lower Control Arm Bushings Sway Bar Bushing Kit with Brackets Polyurethane Tie Rod Boots *All Black Bushings Are Graphite Impregnated Polyurethane |
Vortec in the works
www.p-s-t.com also has reasonable prices
68? It's all figured out untill you get it apart. Is it Sunday yet??? 68 Project 68 SWB frame off/98 Vortec with stock FI/power everything. 95 ECLB 2500 with 346,000 on the clock(the original HD) 99 Lesabre-wifes ride 08 Crew Cab LTZ-All Mine 89 SWB 5/7 drop-Son's first ride. |
thanks for the info
