Old 08-27-2014, 12:51 PM   #76
61K10
61K10's Avatar
Re: 4x4 Power Steering
you have to mod yours or have a machine shop make you one. no aftermarket avl.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 08-27-2014, 01:52 PM   #77
tugster67
tugster67's Avatar
what was wrong with the last one?
tugster67 is offline   Reply With Quote
Old 08-27-2014, 09:18 PM   #78
61K10
61K10's Avatar
don't understand? what last one?
1961 chevy K10
Old 09-05-2014, 11:21 AM   #79
tugster67
tugster67's Avatar
Originally Posted by 61K10 View Post
My steering box and pitman arm are like Ron's pic (88 up with o-ring hoses) which shouldn't make any diff. is the hole in the stock steering arm(on axle) tapered? the info i got was the rod end will fit the hole and it is from a 85 blazer. also their was no mention of shortening the steering arm on axle. haven't pulled my stuff apart yet as i pulled my acl and am gimping around. here are some pics of the new drag link and part #'s. post all your info you find out too. i have captfab's plate and i do have the front eng mount cross-member. hope this helps some.
can you tell me the lenth of your right and left tie rods after its put together with the drag link? I need it to be 12 inches so it will fit from my steering arm to my pitman arm?
Old 09-06-2014, 03:34 PM   #80
61K10
61K10's Avatar
I guess this is what you are asking? you drag is adjustable. you cannot use the org one.
1961 chevy K10
Old 09-06-2014, 06:17 PM   #81
tugster67
tugster67's Avatar
yes that is what i was asking and where did you find a new steering arm, I looked all over and couldnt find anything!!! See My body is a 67 c-10 but my frame is from another year because it has the closed knuckle with the dana rears and I cant tell what year it is but my guess is early 1960's?
Old 09-06-2014, 08:31 PM   #82
padresag
67 had the closed knuckle.
ron
padresag is offline   Reply With Quote
Old 09-07-2014, 01:46 AM   #83
Captainfab
60-66 Nut
The closed knuckle Dana 44 front differential was used thru at least '69.
Old 09-07-2014, 09:45 AM   #84
tugster67
tugster67's Avatar
The new steering arm? Can you tell me where you purchased it?
Old 09-07-2014, 12:58 PM   #85
61K10
61K10's Avatar
my steering arm is the stock one. it has been shortened as been said in this thread.
1961 chevy K10
Old 09-07-2014, 02:18 PM   #86
tugster67
tugster67's Avatar
i know its stock but where can i get one?
Old 11-07-2018, 03:12 AM   #87
James61K10
James61K10's Avatar
my modded steering arm and the piece that got cut out
Adding one more build to the 4x4 channel. I was inspired by the thought of re-machining the steering arm instead of cutting/welding. Ended up looking fairly sensible; I was able to keep the original angle and machine a flat for the nut to clamp against without losing any x-section where the load is applied.
Sorry pics are rotated 90° - Apple “thing.”
James61K10 is offline   Reply With Quote
Old 11-07-2018, 02:50 PM   #88
61K10
61K10's Avatar
I thought about doing something similar to mine also. Thanks for posting.
1961 chevy K10
Old 06-14-2024, 08:59 AM   #89
_mg
Active Member
_mg's Avatar
Checking in to see if there any recent updates or suggestions for the shortened steering arm. Planning to add PS with original 64 K10 front axle. Is cut and weld preferred or milled and drilled, or other options? Thanks.
_mg is offline   Reply With Quote
