06-10-2024, 11:29 PM | #1 |
Brake pedal return spring - 64 C10
Have found some posts on this but none of them list where they found a spring that works.
It looks like I need a 5" spring with ome of the hooks a little longer than the other side, found some prospects on lowes website. Don't know how strong it needs the be, the one I am looking at is probably going to be too much at 40lbs. Had anyone found a good options, online or a common hardware store. Will hit up tractor supply and ace hardware to see if they have something that could work. I do have the parking brake spring that voes under the truck I may try to cut down and use. Have searched online and none of the normal sites I have used list ome, classic parts, lmc, brother, etc...
1964 C10 Resto-mod 5.3L - L59 |
06-11-2024, 12:41 AM | #2 |
Re: Brake pedal return spring - 64 C10
I could not find the original spring also. I ended up using a spring from the hardware store. I don't recall how strong it is.
06-11-2024, 01:24 PM | #3 |
I Found this for a Brake Spring
https://store.fillingstation.com/det...RN_SPRING.html Detail: SA-455 - Chevrolet 1940-1966 BRAKE PEDAL RETURN SPRING - The Filling Station 1940-1966 BRAKE PEDAL RETURN SPRING Item ID: SA-455 Make: Chevrolet Price: USD $6.50 This brake pedal return spring fits 1940-1966 Chevrolet & GMC cars & trucks. Overall length is 5" long. Replaces GM# 3653271, 3698665 Specific Applications: 1940-1954 Passenger cars; 1947-1959 Trucks; 1960-1966 Trucks - Series 20-30 (D-D) This part fits most 1940 1941 1942 1946 1947 1948 1949 1950 1951 1952 1953 1954 1955 1956 1957 1958 1959 1960 1961 1962 1963 1964 1965 1966 Chevrolet Cars and Trucks.; exceptions may apply. Please read the complete description to see if this part fits your specific vehicle and application.
MusicMan70 1961 GMC Suburban |
06-11-2024, 07:37 PM | #4 |
I saw that one earlier, didnt know if it would work since its for a c20.
Just ordered it, will take a chance on it. If not will hit up some hardeare stores I guess.
06-15-2024, 04:19 PM | #5 |
Yeah that spring didnt work, needs to be atleast an inch longer or I just cant pull it far enough. Reworked the arm on brake pedal and got it were it doesnt need a return spring, brakes feel much better now too. They werent bad to begin with but the pedal now has more push back than before and doesnt go down as far with same stopping power.
Just added a 1/4" to the bar I have welded on the pedal to mate up with eyelet on booster rod.
