Old 06-13-2024, 03:00 PM   #1
oneshotkyle
Active Member
68 inline 250/th350 complete runner
Complete running Chevy 250 inline 6 cylinder out of 68c10 pickup. Rebuilt at some time has brass freeze plugs. Mileage unknown but cant be much. Starts and runs as smooth as they come. Completely re-sealed valve cover, lifter covers, timing cover, oil pan. Used new grade 8 bolts in everything. New water pump, 160 degree thermostat, mechanical fuel pump, HEI distributor, plugs, build to fit plug wires, 1 wire 65 amp alternator, ebay polished 1 barrel carb w/electric choke, 153 tooth flex-plate, high torque starter and 7 blade clutch fan. Custom made fuel and vacuum lines. Turbo 350 rebuilt with a stage 2 shift kit. This is a running package and can be driven before purchase. It is currently in a 68c10. Could be sold with new radiator, shroud and hoses additional. I also have a Saginaw 3 speed with bell housing and correct starter for that. And a new 11” clutch and flywheel.
3000.00
Looking for a 4l80e for my ls swap. So consider trades
oneshotkyle is offline   Reply With Quote
Old 06-15-2024, 04:58 PM   #2
oneshotkyle
Active Member
Re: 68 inline 250 complete runner
Another angle
Old 06-15-2024, 05:36 PM   #3
54blackhornet
54blackhornet's Avatar
That’s a real deal ! Good luck on the sale.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 06-15-2024, 08:28 PM   #4
oneshotkyle
Active Member
Lots of old trucks out ther without an engine. Should make a pretty easy install for someone
Old 06-17-2024, 03:13 PM   #5
oneshotkyle
Active Member
Here’s what the main looked like
Old 06-18-2024, 12:38 PM   #6
54blackhornet
With the ridiculous costs to rebuild and the lack of reputable shops this is a no brainer.
71 C-20
07 Magnum RT AWD
Old 06-18-2024, 02:54 PM   #7
oneshotkyle
Active Member
My buddy just had his 250 bottom end redone. All parts and machine work was over 2100 without assembly. This is a deal and excellent shape for someone. Plus you can hear it and ill take you for a ride in it before purchase
