Old 06-16-2024, 10:33 PM   #1
K10-Kansas
K10-Kansas's Avatar
How far do wing windows open?
How far do wing windows open? Mine opens 90 degrees so they are perpendicular to the door. They scratch the door paint if I try to open them farther.
If I could open it past 90 degrees it would really direct the wind into the cab.
This isn't a great pic. I'll try to take a better one.
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James
K10-Kansas is offline   Reply With Quote
Old 06-16-2024, 11:28 PM   #2
HO455
HO455's Avatar
Re: How far do wing windows open?
That looks like it is open fully. There is a stop built installed on the pivot shaft to limit the windows movement.
Photo one shows the window fully open with arrow pointing to the limiting tab.
In the second photo the arrow shows the limiting tab in the fully open position.
Photo three shows the window half open..
It should be possible to modify the limiting tab to allow the window to open further. GM had a reason to put the tab in. It might have been to prevent stressing of the upper pivot point. GM doesn’t install pieces without a good reason.
RIP Bob Parks.
Old 06-17-2024, 11:25 AM   #3
K10-Kansas
K10-Kansas's Avatar
Thanks W0455, I didn't know about the limeter. When I bought the truck a few years ago
the wing window rubber was all cracked up. Every piece of hardware in the bottom of the wing window was rusted solid and half the metal was gone deteriorated away. I bought new wing windows at LMC and I didn't test to see how far they open before I put them in. I can't open mine very far because they hit the door. I can open them a little more than 90°. Maybe it's 100°. If I've got a limiter on these new wing windows, it's not a factor. Hitting the door happens first.
Old 06-17-2024, 11:26 AM   #4
K10-Kansas
K10-Kansas's Avatar
Can anyone open their wing window past 90°, perpendicular?
Old 06-17-2024, 11:38 AM   #5
dmb
Active Member
dmb's Avatar
I can on my 1965
Old dogs and children and watermelon wine
dmb is offline   Reply With Quote
Old 06-17-2024, 01:48 PM   #6
70STOVEBOLT
70STOVEBOLT's Avatar
I can open mine pretty far. I will take some pics when I get home from work.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 06-17-2024, 01:54 PM   #7
K10-Kansas
K10-Kansas's Avatar
Thanks, I appreciate it.
Old 06-17-2024, 03:51 PM   #8
70STOVEBOLT
Here are pics.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 06-17-2024, 04:22 PM   #9
K10-Kansas
K10-Kansas's Avatar
Here are pics.
Thanks. You definitely have a lot more clearance than I do.
Old 06-17-2024, 04:29 PM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
My '72 opens about the same as 70STOVEBOLT's pics above.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 06-17-2024, 04:30 PM   #11
70STOVEBOLT
Something’s not right with your vent window. The shaft is bent or the frame is tweaked, or something. The angle of the window in your pic in post 3 is too great.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 06-17-2024, 05:00 PM   #12
K10-Kansas
K10-Kansas's Avatar
Its brand new. I think that's the problem. Reproduction parts as kind of lousy I guess.
Old 06-17-2024, 05:13 PM   #13
54blackhornet
54blackhornet's Avatar
I have never seen one hit the inner door frame ?
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
