Junior Member
![]() Join Date: Nov 2018
Amp gauge to volt meter kit
Has anyone did one of these volt meter conversion kits on successfully? I put one on and the voltmeter works, but my temperature gauge went over to H and stayed there. Any ideas?
![]() Join Date: Feb 2016
Re: Amp gauge to volt meter kit
Here is a thread that should help you find your problem.
http://67-72chevytrucks.com/vboard/s...perature+guage
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() ![]() Join Date: Jan 2005
Describe how you wired in the voltmeter. If you tied the voltmeter to the temperature gauge for 12V, then I'm wondering if maybe you connected it to the wrong terminal on the temperature gauge.
Junior Member
I wired it according to a sketch Tbone sent. I'm thinking maybe I have the posts of the temp gauge grounded to the tin. I'll check it out today. Thanks for the reply.
Junior Member
I found the problem.... my error....while installing voltmeter, turned the insulated breaker left and right and it goes up and down. Didn't damage anything, just pegged the temp gauge to H. Thank you guys for being willing to help. Have a great day
Breaker??? I believe you're talking about the meter resistor..
![]() Join Date: Feb 2002
I didn't know any conversion kit was needed to convert from an Ammeter to a Voltmeter?
Junior Member
It's a later model voltmeter with a the face plate changed and voltmeter graphics on it. Tbone did make and sell them. I'm not sure if he still does. I couldn't find where he had posted anything recently. The amp gauge was replaced because it never worked. Have a great day.
