Old 05-30-2024, 10:05 PM   #26
fauXGT
fauXGT's Avatar
Re: Under bed gas tank with side feed?
Any GM EFI/TBI tank can work. Then it will be baffled, have return port, breather and can take a combo pump/sender. Then, say an in-tank Walbro or Aeromotive pump for longevity. In the tank, the fuel surrounding the pump will run cooler, so minimize the challenge of " how far can I go on this tank". It shortens the life of the pump.
I just went for the 'Tanks' 50 Chevy for size, EFI ready, custom sender capable for the Bosch gauge and filler location... and it was about the same as anything else new. I think cheaper than what some are charging for the custom between the frame aluminium AD Chevy truck tanks.
Chip
'51 Chevy 3600 5 window
C4 Vette front/rear suspension & drive train
full Rusto-Mod
'92 GMC Sonoma GT VIN #0015
'91 GMC Sonoma GT extended cab 1 of 1
fauXGT is offline   Reply With Quote
Old 06-04-2024, 06:56 PM   #27
58CameoAZ
I purchased a Boyds Welding LLC 63-72 Side fuel tank, set up for my EFI,
this is on my 58 Cameo and planning on filling just behind the Cameo Taillight
to gain access to the gas fill.
You might want to look over there tanks to see if one will work for your truck?
Happy with mine so far!
Allen
58CameoAZ is offline   Reply With Quote
Old 06-06-2024, 11:15 AM   #28
vintovka
vintovka's Avatar
No matter how you do it getting the tank out of the cab is the best thing you can do.
vintovka is offline   Reply With Quote
Old 06-06-2024, 02:28 PM   #29
58CameoAZ
Allen
Forgot to say i am using C4 Front and rear on my truck also with Flat Out Engineering kits.
For what its worth.
Allen
Old 06-06-2024, 03:36 PM   #30
leegreen
did you run tailpipes out the rear past or under the tank? That is one of OP's concerns.
leegreen is offline   Reply With Quote
Old 06-06-2024, 04:05 PM   #31
58CameoAZ
Haven't gotten that far yet, but plan is to run my exhaust up and over each side of the center of the diff OR just under the center of the diff.
I've seen it done both of those ways on other trucks and seams to work? and then maybe along side the tank and out each side?
Got my oldest Son, my Engineer, looking at it to determine the best route, Lol..
Allen
Old 06-06-2024, 05:43 PM   #32
vintovka
vintovka's Avatar
Originally Ran mine down before tank due to concerns. The ungodly drone made me reconsider fast and ran them under tank but with sufficient heat clearance. 4" lift gives you many options you don't get on stock or lowered.
Old 06-07-2024, 01:09 PM   #33
JDarby
Active Member
For what its worth.
Allen
I'm doing the same with a C4 FlatOut Engineering Kit on my 55.1 GMC 100!
1955.1 GMC 100 RestOMod
1972 T120RV
1967 C200 Trail 90
2014 TRD Quad CAB
JDarby is offline   Reply With Quote
Old 06-21-2024, 12:40 PM   #34
JDarby
Active Member
A 68-70 El Camino fuel tank has the same dimensions as the amount of room I have available for a tank which is 42 x 25 x 9!
I do want a side feed into the fender on the drivers side.
Have any of you tried that tank in your AD truck?
And if so how is it working out for you?
Summit has them for 329.00 with notched corners and set up for efi!
1972 T120RV
1967 C200 Trail 90
2014 TRD Quad CAB
Old Today, 06:32 PM   #35
Robert Crandall
Jim Carter has reproduction Suburban tanks. Maybe that would work.
https://oldchevytrucks.com/meg149.html
Robert Crandall is offline   Reply With Quote
