Old 06-23-2024, 07:18 PM   #1
pjmoreland
pjmoreland's Avatar
Vacuum Gauge Installation
Here's a short video that gives an overview of the method I use to install a stock-style (reproduction) vacuum gauge in a factory gauge cluster. The only purchased items are the gauge and the decal material.
https://youtube.com/shorts/W6D0dcKrsCc?feature=shared
pjmoreland is online now   Reply With Quote
Old 06-23-2024, 10:01 PM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Vacuum Gauge Installation
Cool. I have a Moon Eyes Vacuum gauge on 919. Bought it in '77 after breaking in my first 292 build. Invaluable gauge when tuning up, a real eyeball on the engine's health when cruising. Also the first indicator of a broken exhaust valve spring.
My nominal with a .030-over 292 is 17.5''Hg. [SBCs with greater displacement might have more Suction.]
Jumps into the 20s when engine-braking.
Drops low on acceleration.
Bouncing needle tells you a valve or lifter is blown.
On a long cruise, you can see if you're getting better economy by easing the acellerator pressure and decreasing RPMs without dropping your Inches of Mercury.
It's the Steam Gauge OBD.
Have one for the '71 Jimmy that I haven't put on yet. An AutoMeter.
Old 06-23-2024, 10:28 PM   #3
Getter-Done
Getter-Done's Avatar
That is Cool.
So, you made your dimple dies out of delrin?
The early bird gets the worm,
84 Chevy K-20
Old 06-23-2024, 10:34 PM   #4
pjmoreland
pjmoreland's Avatar
I like having a vacuum gauge. Might not be the most useful gauge on the dash, but it can't hurt.
Old 06-23-2024, 10:41 PM   #5
pjmoreland
pjmoreland's Avatar
Originally Posted by Getter-Done View Post
That is Cool.
I designed them using SolidWorks and then had them 3D printed out of PLA. The gauge cluster metal gets bent at 90 degrees at the bottom of the opening with a sharp corner, and 72 degrees at the top with a large radius. It was an interesting challenge to model that accurately and have the two bend profiles blend together smoothly.
I put grease on them during use, and they form the metal very easily. I'm not seeing any wear on them at this point.
Old 06-23-2024, 11:05 PM   #6
Getter-Done
Yes, I noticed the profile differences.
Great work.
I may try this with some delrin.
Thanks for the Idea.
84 Chevy K-20
Old 06-23-2024, 11:06 PM   #7
Cwood0425
Explorer
Cwood0425's Avatar
Looking Good
Older than Some and Younger than Some, but I am still here
............... ____
.. ________//__{\____
/__(O)___//___/_(O)_/
Cwood0425 is offline   Reply With Quote
Old 06-24-2024, 07:45 AM   #8
1970cstblazer
1970cstblazer's Avatar
Thumbs up Re: Vacuum Gauge Installation
You are definitely a craftsman. Very nice work.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 06-24-2024, 09:54 AM   #9
pjmoreland
pjmoreland's Avatar
Thank you
