Re: 60 series to 1/2 ton engine swap
a look at the assembly manual for your truck would show the two set ups, I6 and V8, and you can see exactly how things go together.
55-59 chevrolet truck factory assembly manual pick the tri5 site, its a free download the trucks came with a V8 that has factory front mounts and a bellhousing with mounts under it. check this link for a thread on this site that explains it with pics to boot https://67-72chevytrucks.com/vboard/...d.php?t=584685 also consider the driveshaft hook up as a trans with a yoke bolted on will need a two piece driveshaft that has a slip yoke on the rear shaft in order to make allowances for suspension movement. |
| Bookmarks |
