Old 12-17-2009, 10:28 PM   #1
justagoodolboy
Under Construction
justagoodolboy's Avatar
Steering Wheel Removal
Don't know what I'm doing wrong but my steering wheel doesn't want to come off.Is there a trick to getting it off or are they just hard to remove?I tried the search but couldn't find anything.Thanks in advance.
72 chevy 4x4-my project
67-72chevytrucks.com/vboard/showthread.php?t=368210
94 Nissan 4x4-Daily Driver and off road beater
03 Saab 9-3 -tripper
90 Polaris Trail Boss- 2 Stroker
justagoodolboy is offline   Reply With Quote
Old 12-17-2009, 10:31 PM   #2
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
Re: Steering Wheel Removal
rent a steering wheel puller from your auto parts store
Michael
1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day)
2006 GMC Sierra Crew Cab 4x4
1969 Lincoln Continental Coupe Project FOR SALE
http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17
1981 Honda CM400 C Bobber SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=384152
wancosc356 is offline   Reply With Quote
Old 12-17-2009, 11:29 PM   #3
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
I went to auto zone. I dont know if they are nation wide, but $20 down and $20 back, and it worked like a charm.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 12-17-2009, 11:40 PM   #4
justagoodolboy
Under Construction
So it just needs a little encouragement,huh?! Thanks,I'll have to check into that.
Old 12-17-2009, 11:45 PM   #5
wancosc356
wancosc356's Avatar
That's correct. The nut has pressed the wheel onto the steering shaft. A steering wheel puller works great. You can either rent one or buy one. No problem. Take it easy.
Michael
Old 12-18-2009, 12:33 AM   #6
leddzepp
Moderator
leddzepp's Avatar
You can buy this kit at Harbor Freight for $10. It will remove steering wheels, pullies, etc. Great investment.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 12-18-2009, 01:25 AM   #7
Beatcoaster
69 Fleetside
Beatcoaster's Avatar
Just buy a steering wheel puller - they are $15 at Schucks...
Beatcoaster is offline   Reply With Quote
Old 12-18-2009, 10:47 AM   #8
justagoodolboy
Under Construction
Thanks for your help,everyone.Before I go buy one,I'm going to check with my local mechanic.He may have one I can borrow.
Old 12-18-2009, 11:15 AM   #9
surfacerust
times are tough, and some of us may not have 20 bucks...
now i know this may sound shady but its worked many times for me. pappy rust taught me this one.
take the nut off and find a regular nut that threads onto the shaft.
thread it on just enought that the shaft dosent protrude out of the nut.
lace your arm thru the wheel pull it toward you. and with the other bump the nut with a small hammer.
be sure you arent hitting the shaft just the nut. and be gentle you can still damage the threads. it should pop off without too much force.
and dont hit yourself in the nose with the wheel when it pops off.
and a little anti-seize on it before it goes back on.
surfacerust is offline   Reply With Quote
Old 12-18-2009, 11:30 AM   #10
Shane
Shane's Avatar
... sounds like a good way to lose some teeth.
do yourself a favor and find a puller ... rent, buy or borrow, it's still cheaper than the dental bills.
Shane is offline   Reply With Quote
Old 12-18-2009, 11:45 AM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I have one like this that I bought many years ago. It was cheap and works great.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 12-18-2009, 11:52 AM   #12
Shock_Me
Shock_Me's Avatar
Yeah they're not too expensive, and it's surprising how many times I've actually used it.
Shock_Me is offline   Reply With Quote
Old 12-18-2009, 12:22 PM   #13
justagoodolboy
Under Construction
I'll probably end up getting a puller somewhere.We tried putting pressure on it and tapping the nut -kind of the same method I used to slide the back axle out of my four wheeler-but it wouldn't budge.I didn't know if there were any tricks or something I missed,but it sounds like I just need a puller.Hopefully I'll get to it today.
Old 12-18-2009, 12:34 PM   #14
mr48chev
mr48chev's Avatar
Use the puller. Guys used to do the hammer trick all the time but it is too easy to damage the collapsible columns and shafts and or the steering boxes on older trucks with solid shafts. Some of those things we "used to do all the time" are made obsolete by the designs of the newer and I mean newer by 68 and up rigs.
From experience it isn't fun to have to repair a steering shaft that someone collapsed by wacking it with a hammer to get the wheel off. One of them is in my 71 and was damaged when one of my uncles redneck buddies changed a turn signal switch for him. When I pulled the stock wheel off to put my custom wheel on the shaft slid down inside the column.
As several said, if you are low on bucks and can't borrow one. Go to Autozone and hand them some money on their rental program, use it and take it back and get the money back.
Old 12-18-2009, 04:00 PM   #15
justagoodolboy
Under Construction
My mechanic/friend said he has one I can borrow so I'm picking it up in a few minutes and then I'm off to my buddy's shop to keep yanking my interior.
Old 12-18-2009, 08:35 PM   #16
justagoodolboy
Under Construction
Worked like a charm! Thanks, guys.
Old 12-18-2009, 10:29 PM   #17
wancosc356
wancosc356's Avatar
Great! Glad it worked for ya!
Michael
Old 06-27-2024, 10:34 AM   #18
K10-Kansas
K10-Kansas's Avatar
I've got a 1967-68 steering wheel and I don't see how the pullers I am finding work. Napa and O'Reilly's have them to borrow for free but j shaped hooks are too fat to fit between the column and wheel and the horn bowl prevents and puller bolt for screwing in. Do you need a special puller for a 1967 wheel?
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James
K10-Kansas is offline   Reply With Quote
Old 06-27-2024, 11:13 AM   #19
LNP
You need to remove the horn pieces so you can access the bolt holes
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 06-27-2024, 12:35 PM   #20
truckster
truckster's Avatar
To expand on that, you remove the horn button and the three screws that hold the horn ring. Under that you'll find two bolt holes, one on each side of the steering wheel nut. Remove the nut, thread a bolt through the puller on each side of the steering wheel hub, and tighten the puller until the wheel comes off.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 06-27-2024, 02:33 PM   #21
K10-Kansas
K10-Kansas's Avatar
Thanks. I'm not sure why that didn't occur to me when I looked at it, that I could take the bowl off. Thanks.
Old 06-27-2024, 04:39 PM   #22
MARKDTN
I can remember getting a Ford truck steering wheel in a junkyard in the 80s. We took the nut off and one of us pulled hard while the other hit the shaft with a big hammer. We didn't care what we did to the column. I'm ashamed of that now.
It's fine thread on GM so not always easy to find a nut that fits. I'm with the get a puller camp. They are handy for balancers too.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old Yesterday, 11:16 AM   #23
vics stuff
Do Not Use This Method you stand the chance of pulling the steering shaft upwards and from the lower steering column bearing. I know , this has happened to me . As the old saying goes , use the wright tool for the job.
Vic
vics stuff is offline   Reply With Quote
Old Yesterday, 05:36 PM   #24
Rust_never_sleeps
Rust_never_sleeps's Avatar
I borrowed the thing LEDZEPP shows and it worked great. Sometimes called a harmonic balancer puller, among other names
I originally borrowed another type (a thing actually called "steering wheel puller), and it was a no-go for me
1970 C10 Custom longbed 350/350
Rust_never_sleeps is online now   Reply With Quote
