Old 06-07-2024, 03:16 PM   #1
aglinks
Junior Member
Fix the '66: Build Thread
Hey all,
I acquired my dream truck and am kicking off the build! It is a mostly stock, mostly rust free 1966 K10 with amazing patina! I bought the truck along with a set of axles form a 1979 K30 (Dana 60 and 14FF).
The plan is 5.3L, SM465, and NP205. I have the engine, transmission, and transfer case ready to go, I just need to decide on an induction system. I am leaning towards a Holley Truck Avenger just to scratch the itch. I have a CJ7 with an LS that I run the stock EFI on, so I dont want to do the same thing over again with the '66.
I started an instagram to document the build as well. The handle is @fixthe66
As soon as I figure out how to add photos, I will post them!
aglinks is offline   Reply With Quote
Old 06-07-2024, 06:15 PM   #2
_mg
Active Member
_mg's Avatar
Re: Fix the '66: Build Thread
Awesome, subscribed!
_mg is offline   Reply With Quote
Old 06-07-2024, 06:52 PM   #3
Shifty One
Shifty One's Avatar
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 06-08-2024, 09:36 PM   #4
lilpoindexter
lilpoindexter's Avatar
lilpoindexter is offline   Reply With Quote
Old 06-08-2024, 09:47 PM   #5
aglinks
Junior Member
Originally Posted by lilpoindexter View Post
I get an error when I try to upload them
Old 06-08-2024, 10:16 PM   #6
aglinks
Junior Member
I get this error when I try to upload
“Your submission could not be processed because a security token was missing.”
Old 06-10-2024, 11:41 AM   #7
aglinks
Junior Member
I think I figured out pictures, the files were too large. I am going to try to post a bunch to catch up!
Old 06-10-2024, 11:42 AM   #8
aglinks
Junior Member
Here is the 305A. I got it running and listed for sale. Since it is not original to the truck, I am going to swap in a better engine for my application.
Old 06-12-2024, 05:45 PM   #9
aglinks
Junior Member
Both studs as well as the spring pin were broken off in the Dana 60. Using various methods, I got them all out!
Old 06-13-2024, 12:03 AM   #10
350TacoZilla
Cool, can't wait to see another 4x4 build on here. Give me some extra motivation for mine.
350TacoZilla is offline   Reply With Quote
Old 06-13-2024, 12:52 AM   #11
aglinks
Junior Member
Thanks! I’ll try to keep the content coming as time allows!
Old 06-13-2024, 04:07 PM   #12
aglinks
Junior Member
I pulled off the old steering box and installed the Captain Fab steering box bracket. I tried to copy the geometry from aotte1 but the brackets on my frame made me mount about 1" further back. Hopefully I can deal with that using the drag link adjustment.
Old 06-18-2024, 06:50 PM   #13
aglinks
Junior Member
I bolted in the tons this weekend.
Front Axle (Dana 60):
Mostly uneventful and was a direct bolt in. I did find a broken main leaf on the passenger side, so I need to address that. I just snugged down the bolts for now.
Rear Axle (Corporate 14 Bolt):
Not so much a direct bolt in. The center to center on the spring pads is narrower on the 1979 axle. It went together but you can see that the springs and the u-bolts are leaning inwards. These bolts are also just barely snugged. New spring perches are on order and I will weld them in place in the right spot.
Old 06-19-2024, 06:00 PM   #14
350TacoZilla
You might want to check out this build thread, page one he starts swapping to newer suspension and eliminates the blocks, can help with ride and parts availability. Good to see you getting work in on the truck, not many 4x4 builds around
http://67-72chevytrucks.com/vboard/s...d.php?t=768827
Old 06-19-2024, 06:07 PM   #15
aglinks
Junior Member
I will likely switch to 73-87 springs all the way around at some point, but not right now. There are too many other costly repairs that this build is going to require. Besides, the stock springs and bushings appear to be in good shape so I am just going to move the perches for now. Perches were only $30 from Ruffstuff.
Old 06-20-2024, 01:07 PM   #16
aglinks
Junior Member
I finished my steering shaft last night. I cut the stock shaft and welded a borgeson universal joint in. The pitman arm is loose on the steering box, so I need to figure that out. And the drag link is just there to check length, I have all new steering components on order.
Old 06-22-2024, 03:24 AM   #17
350TacoZilla
Got ya, I was just suggesting it since you had found a broken main leaf and would be revisiting the rear suspension at some point.
Old 06-26-2024, 01:25 PM   #18
aglinks
Junior Member
I went through the un-known mileage 5.3 that will be going in the truck. It was disgusting, so I pressure washed and painted everything. I changed every gasket and seal with the exception of the head gaskets. I put in a new melling oil pump. The timing chain was tight and the internals looked good. I also found this tag on the head that tells me that it MIGHT be rebuilt. Overall I am into this engine ~$200
I got a Holley intake and MSD box for cheap on Ebay and will run a Truck Avenger clone for now. I am insisting on a round air cleaner when I pop the hood, so I wont be running the stock LS EFI. If I struggle with the carb, I will get a Holley Sniper.
Old 06-27-2024, 05:01 PM   #19
aglinks
Junior Member
I stripped the rotten insulation off of the floor and wire wheeled, scrubbed, and pressure washed all the grime. Then I painted it with two coats of POR15 Grey. I have one small rust hole to repair on the driver side, but everything else is solid! Once I have the new engine/trans bolted in, I will patch the hole for the old T-Case, and throw in some carpet.
Old 06-27-2024, 05:12 PM   #20
350TacoZilla
Looking good man! and yeah that looks like a reman engine tag so if the motor overheated they know not to warranty it. Depending on who did the rebuild that could be a good thing with fresh bearings and rings etc but some horror shops out there still.
Old 06-27-2024, 05:37 PM   #21
aglinks
Junior Member
Well I am going to run it and see what happens! I got the engine for free and spent very little on gaskets, seals, and a new oil pump from Rockauto.
