Old 06-25-2024, 10:07 PM   #26
cericd
cericd's Avatar
Re: Door Hinge Stop / Check Pads
Here's a thread about replacing the friction pads and it looks like they didn't remove the doors or cut the roll pin.
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 06-25-2024, 10:39 PM   #27
Getter-Done
Getter-Done's Avatar
Originally Posted by Rich72C10 View Post
If I have to resort to cutting/driving out from both sides - not sure how I could do that without taking the hinge off the truck. But I can see why that might be required
Is it correct that a 3/16" drift it is smaller than the 3/16" pin (allowing it to go into the hole)? I could look for a carriage bolt and use my digital calipers, perhaps 4.5mm is small enough? Anyone able to measure one of these 3/16" drifts with digital calipers for millimeter size?
3/16 = 3 / 16 inches = 4.7625 millimeters
84 Chevy K-20
Old 06-26-2024, 06:21 AM   #28
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
He made it look simple, that's what I want to do. I wonder how he got that punch he has in this photo to work. Doesn't seem long enough to push from the top!
I get that but I thought the hole ended up being smaller than 3/16? I guess I misunderstood.
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 06-26-2024, 06:24 AM   #29
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Also why is 67-72 Door: Friction Pads closed? That's strange, I don't see anything that went sideways.
Richard
Old 06-26-2024, 10:35 AM   #30
leddzepp
Moderator
leddzepp's Avatar
That thread is in the FAQ section, all threads there are closed after they are cleaned up and consolidated.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 06-26-2024, 10:44 AM   #31
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Oh, gee - that's what I get for not looking in the Faq section - Doh!
Richard
Old 06-28-2024, 06:28 PM   #32
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
If you get the right tool, for the right job - sh*t will work!
TEKTON 3/16 Inch Roll Pin Punch #66066 off Amazon for $7.58 dollars. I also ordered a TEKTON 5/32 Inch Roll Pin Punch #66065 but its running late, it would have been useful pushing the later one back out.
I'd image all these days soaking with Free-All has helped but I hammered it from the top and down out of the bottom. The 1st few hits I didn't think it was going to move but then it did. After that only a 5 or so hits. I was using a regular claw hammer, so it isn't very heavy. Using a nice ball ping hammer likely would have been better.
Now to get the pads in but I'll do that tomorrow morning when it is cooler :-)
Richard
Old 06-28-2024, 07:04 PM   #33
cericd
cericd's Avatar
Congrats on successfully removing the pins and thanks for the heads up on the punches used.
Chris
Old 06-29-2024, 07:25 AM   #34
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Thanks guys for all the help and tips. No more floppy door - YAY Me!
I clearly was overthinking this project and worrying about how the split pin's hole reduced. If I had the right tool (3/16 Inch Roll Pin Punch) to begin with I doubt I would have been fussing with all my posts.
Aside from not starting with the right punch, the hardest part is when the top pad fell into the door cavity. It fell in-between the outer skin and the tub (kind of like a seam) just far enough I could not reach / feel it with my hand. I ended up putting my snake camera into the door and using my magnetic stick to find it and to get it out. So Pro-Tip: don't let those pads drop into the door! The top pad is prone to fall out until you get the wedge in, because it needs to raised up by the wedge to be kept in place.
Again, thanks for the help!
Richard
Old 06-29-2024, 09:25 AM   #35
1970cstblazer
1970cstblazer's Avatar
Thumbs up Re: Door Hinge Stop / Check Pads
Congrats on a PITA job!
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 06-29-2024, 10:33 AM   #36
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Thanks - in hindsight it wasn't so bad. Though I'd image that pin could be a lot worse off in a lot of trucks, so perhaps I was a bit lucky.
For the record I did end up just reusing the pin that I pushed out. I seriously doubt I'll ever take it out again. I did clean it a bit and rubbed some grease on it.
Richard
Old 06-29-2024, 11:24 AM   #37
dmjlambert
dmjlambert's Avatar
Hi, can you please explain further what you mean by "I also ordered a TEKTON 5/32 Inch Roll Pin Punch #66065 but its running late, it would have been useful pushing the later one back out." What does "later one back out" mean?
Old 06-29-2024, 11:36 AM   #38
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
When I hammered down the 3/16th punch down, it was a bit wedged in the hole(s) and I could not pull it out by hand. So I used a old drill bit and put it in the bottom hole (where the pin fell out) and hammered up to get the 3/16th punch out from the top.
Richard
Old 06-29-2024, 12:32 PM   #39
70STOVEBOLT
70STOVEBOLT's Avatar
Is removing and installing the pads pretty straightforward? In the door.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 06-29-2024, 12:53 PM   #40
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Very straight forward - the whole process is pretty easy - once you have it done and look back. Assuming your pin isn't seized or bent, it should take about an hour.
  1. Pre-spray pin, I used Free-All. It actually sat for a few days soaking.
  2. Use something like a TEKTON 3/16 Inch Roll Pin Punch #66066 and hammer it out from the top. I found trying from the bottom a real PITA.
  3. Use something like a TEKTON 5/32 Inch Roll Pin Punch #66065 to get the above punch out.
  4. Remove inner door skin, if you haven't a Window And Door Handle Removal Tool you better get one - I've had one since I was a kid.
  5. Reach into the door to catch the wedge has you push it into the door cavity
  6. Remove old pads.
  7. Install new pads. The bottom will set into its notches, the top pad you need to hold it up into the notches or it can fall out into the door (which sucks if it does).
  8. Push wedge from inside of the door cavity in-between the new pads and put pin back in.
  9. Put inner door skin back on, job done!
I wasn't able to push the wedge very far by hand but I was able to get it far enough to use my 5/32 Inch Roll Pin Punch to mount it, then open the door, which pulled the wedge through the new pads. Using the 5/32 Inch Roll Pin Punch also lined everything up for the split pin. Then I hammered in my original split pin in with the 3/16 Inch Roll Pin Punch. I didn't use a heavy hammer, just a simple claw hammer.
Oh, you may want to use a lot of Blue Tape anywhere/everywhere you think your hammer could hit if you miss or slip off the punch...
I hope the above made sense, if not happy to follow on any questions.
Richard
Old 06-29-2024, 03:56 PM   #41
dmjlambert
dmjlambert's Avatar
Thanks for that great info. It is especially good to know the correct tools to use. It would be good if a moderator could open the FAQ thread and put a link to this thread in, and re-close the FAQ thread. Good documentation.
Old 06-29-2024, 04:59 PM   #42
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
FYI: I put a summary into my 1st post, just in case someone finds this later and doesn't have to read all the fluff posts as I figured things out.
Richard
