Load and heat
So...I've got this bus bar where everything connects. All the power grabbers and the power adders (alt, batt) all connect to the bus bar. While playing with my fan setup today I happened to notice my bus bar has some heat in it at full load (elec fans, A/C, blower on high, lights on bright). Measured the heat at about 150F on the bus bar. I was feeding the bus bar from batt with 4AWG but changed that to 2AWG today. After doing this I had more total voltage at the batt than before (14.5VDC) so I'm sure the 4AWG cable wasn't enough, however the heat in the bus bar didn't really change. The bus bar has these ratings: * Continuous amperage of 130 amps AC, 150 amps DC * Maximum voltage rating 300 V AC, 48 V DC My alt is 140amp and my estimate of the amperages being pulled through there were below 150, the max rated for this bus. What are your thoughts on this heat...I'm sure it's been running this way since the day I rewired everything. All power leads off bus bar are fused with either in line or fusible link. -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
Re: Load and heat
Is there a temp spec with the buss bar? If the bar is in the engine compartment, under hood temps are probably higher then 150* anyway.
If the buss bar terminals allow, might move the heaviest load to the same terminal as the Alt wire so that load isn't flowing through the bar. Put the heavier loads in the middle with the alt and the lighter ones on the outsides. Minimize the bit of bar carrying the heaviest load. |
#3 | |
Re: Load and heat
I'm not finding a temp spec for it. I'll rearrange the leads in this manner as it does seem logical. I'm running 6AWG from the alt to bar which I believe should be adequate. Good point about the engine compartment heat however I'm certain the leads also have a bit of heat in them...at least the heavy electric fan leads to the relays do. Thanks much, -Kevin
Re: Load and heat
I placed the 3 electric fan leads along with the Alt lead on the same lug in the middle of the bar and distributed the remainder on the other lugs. This changed things for the better in terms of how the system reacts to high draw fans kicking on and the in dash volt gauge now reads much closer to actual at-the-battery volt readings. This gauge thing may have been the result of changing the 4AWG batt to bar cable to 2AWG. Thanks again, -Kevin
BMW & ASE Master Certified
Re: Load and heat
are the terminals on the wires crimped properly? if not, that could be causing the issue.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
#6 | |
Re: Load and heat
I’m no expert but these are all 10 and 12 gauge with crimped terminals. I used appropriate sized noninsulated ring terms and tried to curl the seam down into the wire strands with the right crimper. Shrink wrap. Shoulda soldered the big ones. Next time I’m there I’ll check the heat at those connections. Thanks! -Kevin
Re: Load and heat
Pictures?
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
![]() Join Date: Mar 2003
Re: Load and heat
Under hood temps this time of year I'm sure will approach the 200+ degree mark. If you are below the AMP rating of the bar I wouldn't worry about it as long as everything is crimped, soldered and tight. Which buss bar bar are you using?
Re: Load and heat
This is the one I have installed. It is about 7" long and beefy. https://www.summitracing.com/parts/qdb-568102 -Kevin
