New Member
![]() Join Date: Jan 2024
68-72 rear end issue
I took the posi diff out of a 68 and put in a 72 rear end housing but now I have axles that have in and out play at the Center diff pin, did I do something wrong or does that swap not work since 68 has a narrower housing
![]() Join Date: Apr 2013
Re: 68-72 rear end issue
What Axles did you use?
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
New Member
Hi I used the 72 axles. So our other 72 doesn’t have any movement against the axle and Center pin, now the 68 posi carrier that I put in the 72 housing with 72 axles works but it has about .140 thousand movement between the end of the axle and the Center pin on both sides, which isn’t right.
I was wondering if the the 68 has thinner spider gears causing this issue amd how can I fix it Thanks JD63 |
#4 | |
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
Have you checked the fit of the drums yet. There are differences in the length of those 2 axles. I don't remember all of it but someone will pop in & explain it. Have you tried using the axles from the 68?
George |
New Member
No I haven’t, but that diff is narrower than my 72, so they wouldn’t work unless I went back to the 68 diff. The spider gear isn’t the problem its the axle moving in and out on the side gear because it’s not tight against the Center pin which is leading me to believe that the axle gears are not as deep as the 72s
So it seems like you're saying that if the c-clip groove in the axle was a little further outward then the axles would sit a bit further INward, against the pin, right?
I think when you put the drums on the will stick out. I think there are special axles for this swap. Of coarse the 68 has 6 lugs & the 72 has 5.
I'm surprised someone more familiar with this has not popped in. George |
![]() Join Date: Jun 2002
JD, if I understand you correctly you are using the 72 axles in the 72 rearend with a 68 center carrier. This should work fine, I have done it before.
When you did the change did you rebuild the clutch pack? If not it probably needs to be rebuilt. If you can rotate one tire by hand with the other against the ground it needs to be rebuilt.
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
New Member
I did rebearing it and inspected all the clutch plates and they looked fine, there certainly wasn’t enough wear to take up the difference I need to. I’m afraid it will wear on the axle c clips being able to move in and out and effect handling
I'm thinking that as long as you install the pin and the c-clip is still trapped in the cup of the gear so it won't drop out you should be okay. BUT i'm not a rearend guy (well kinda...) but I have had axles out of lots of these trucks and there is usually some play.
#12 | |
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 Last edited by LNP; 06-25-2024 at 10:38 AM. Reason: cant type lol |
New Member
I’ll do some checking and post what I find
New Member
Re: STUMPED. 68-72 rear end issue
Hi
I took a reading and it’s 40 thou play. I have pictures but can’t seem to load them. So 72 housing. 72 5 bolt axles. 68 posi unit rebrg 40 thou play on axle to Center pin on both axles Everything looked normal when cleaning diff up. All plates that were there were installed but it’s like it’s missing one one each side which would push the axle gears closer to the pin to eliminate the play, but that won’t work as then the spiders wouldn’t fit. 🤨 Thanks for everyone’s ideas so far Jd63 |
#15 |
0.40 is a lot obviously theres something different between the two years in the differential. If you ever do figure out what it is let us know. Sorry I couldnt help ya more.
#16 |
New Member
Yeah and I’ve tried different 72 5 bolt axles and it’s the same thing. The end of the axle just needs to be a bit long after the c clip and it would butt up against the Center pin and all would be good.
I could go back to the 68 housing and buy new axles or stick with the 72 and buy a new posi unit I guess are my two options at this point unless there’s another way to resolve my problem . Thanks Jd63 |
#17 |
Just out of curiousity whats the difference between the 68 & 72 axles themselves?
#18 |
Born Psycho
![]() Join Date: Feb 2001
68 axles are 6 lug and shorter.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
#19 |
Too bad not a hair longer. The six lug is not a big deal as I machine shop could redrill the for 5 lug. Oh well it was worth a thought.
#20 |
New Member
Yeah I figure by the time they redrill the holes at todays shop rate I will just buy new axles if we go that way
#21 |
I'm not for sure what they charge would be worth lookin into both ways if you go that route
#22 |
New Member
Yeah I’ll post the answer if I ever stumble across the solution, I was hoping one of the many truck enthusiasts would have the answer.
#23 |
![]() Join Date: Mar 2015
#24 |
New Member
Yep I know that, but we’re out in the country and limited service’s
#25 |
40 thou is .040 not .40
If it is .040 I would run it, if it is .40 I would not.
