Junior Member
![]() Join Date: Sep 2023
vacuum switch out to hydraulic power assist
C10 71 350.
Very low vacuum causing vacuum brake assist to be inadequate on long steep downhill driveway with s turns. Bought the hydratech actuator. 90-120 days to receive from date of order but a nice US unit. Running a Concept One pulley system so had to change out PS pump and add a remote reservoir. Mounted the reservoir where the old radiator expansion tank was. Bought cylindrical metal expansion tank and mounted it between the grill and radiator support. Made new hydraulic lines. Did not make one fitting properly on the high pressure line and squirted PS fluid everywhere in the engine bay. Lots of smoke from it landing on the exhaust. Noticed the short from plug wire to header. Bought shorter plug and ceramic cap. Accel had both the shorter header plugs and the ceramic cap/wire. Started testing yesterday outside my house. Short runs and hard breaking. Then the adventure down the hill. Said goodbye to the wife and told her to come look for me if I was not back in ten minutes..... All went well. Could stop on the steep hill and lock wheels if necessary. Could not do that before making every trip down the hill an adventure. Lessons learned: 1. Stainless braided lines tear up your finger tips and are cause swearing out loud. 2. These changes always cost more than you planned. 3. Having great tread on the tires does not mean they are safe to drive on. Whilst wheels were off, the date date stamp was three digits....that means a minimum of 20 years old. Bought new tires. 4. Improvements like this project are very satisfying! Cheers Tim |
![]() Join Date: Jun 2022
Re: vacuum switch out to hydraulic power assist
is your motor cammed?
1970 C10 Custom longbed 350/350 “Carburetors are forgiving, timing is not” — Thunderhead289 |
Junior Member
Yes. According to the info from the engine builder its a 1104 466 lift. Heads are LT1 #3927186.
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
Nothing like weak brakes on a steep hill to cause high blood pressure. Good thing you got it fixed!
Junior Member
Went for a drive yesterday to drop off screen door trashed by my dog. Hot day in Livermore. All good there and back. The braking takes a bit to get used to.
Hydradtech says it can take up to 500 miles to get the microbubbles out of the system. |
![]() Join Date: Feb 2022
Your description of the project is so dead on. I don't play golf but I bet those guys get the same feeling as us. Frustrating as hell but at the end of a good round so satisfying. Liked the braided line comment. Same here until I figured out some tape and a Dremal cut off wheel makes a very clean cut. Don't go all the way through so you don't contaminate the tube, and finish with razor blade. Way less stray wires to poke in the fitting.
#7 | |
hydro systems look cool, just a bit of initial work Hotter the rest of the week, joy
So did the dog get to ride along when taking the screen door in? If so then he/she is much smarter than you give him/her credit for!
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks, a 5 speed AND a front hitch! |
Junior Member
Actually he did! The gal at the screen shop asked me if I still had the dog.....
Heavy duty mesh going in this time. Maybe electrified.........but for sure the wife will walk into it and then things will be bad! |
Your dog went to great lengths just to get a ride in the truck, most of us do the same thing....I think I would cook that guy a T bone
| Bookmarks |
