Old 07-04-2024, 06:40 PM   #1
Ironhorse
Ironhorse's Avatar
73-80 Hooks on 72 Frame?
Was asked this from a friend of mine who recently bought a project 72 4x4 long bed with tow hooks on the GB list. Naturally they are no longer there. A long term project and he knows finding original hooks will be pricey and asked about the 73-80 J style hooks as a stop gap? Have never seen anything that I can remember about their use on the earlier 69-72 frames. He mentioned the re-pop hooks and think I talked him out of wasting his $$ on them. Would never consider re-pops on any 4x4 I personally own.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 07-05-2024, 04:09 PM   #2
Orange Crate
Orange Crate's Avatar
Re: 73-80 Hooks on 72 Frame?
You can still get these here:
https://www.clevelandhardware.com/ca...=pdfs/2800.pdf
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...
Orange Crate is offline   Reply With Quote
Old 07-05-2024, 08:44 PM   #3
Ironhorse
Ironhorse's Avatar
Originally Posted by Orange Crate View Post
Yup, those are readily available locally but he was wanting to know specifically about the 73-80 "J" style hooks mounting to a 72 frame. It's a temporary fix while he addresses many more and larger issues.
Wellington, Ks
Old 08-11-2024, 05:22 AM   #4
dennislbrooks
dennislbrooks's Avatar
I use the square body hooks on my 67 frame. I just like them better. My 60-68 hooks are under the seat - prior pics.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 08-11-2024, 03:29 PM   #5
Ironhorse
Ironhorse's Avatar
Those square body hooks look right at home on your '67. Any issues in getting them spotted against the frame/bumper area. My '71 K10 did not have hooks on it when I bought it. All it did have was a LOT of rust and dings, LOL. When I installed the '69-'72 hooks all I did was spot them to the frame horns with good clearance all around, marked the spot and drilled. Had to finish the 5/8'' holes with a grinding bit. Took a bit of grinding out to size but worked fine.
Wellington, Ks
Old 08-11-2024, 04:16 PM   #6
dennislbrooks
square body hooks on 67
