06-30-2024, 07:39 AM | #1 |
Increase 1967 C20 3/4 ton load carrying..
Add load carrying capacity. Extra Springs?
I will add front sway bar. I can carry 200gal water fairly well. Tank is back due to tool box. Like to be able to safely haul 300gal. |
06-30-2024, 09:21 AM | #2 |
Who Changed This?
Re: Increase 1967 C20 3/4 ton load carrying..
Adding a rear sway bar would help too, but that's really a job for a 1T truck, since the tank's over a ton when full.
06-30-2024, 09:54 AM | #3 |
What’s the GVWR in the plate? My 72 c20 is 7500 lbs the truck itself is less than 5k . So over 2500lbs capacity that’s the approx weight of 300 gallons of water . I would go from there .
Lots of limitations on old trucks . Age of the springs and axles is one as is the braking system. Drums would have a lower ability to stop a fully loaded truck . But modern E rated tires are better than old bias plies so that’s a plus . Also 4x4 trucks usually have less payload and GCVWR because they are usually heavier than their 2 wheel drive counterparts.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 06-30-2024 at 10:28 AM. |
06-30-2024, 10:51 AM | #4 |
If you have leaf springs, find a set of Helwig helper springs. I rolled across the dump scales many times over 10k hauling broken concrete about 15 miles. Obviously way overloaded, it was 45 yrs ago and I was invincible. Put many more miles on the truck after that project. 71 c20 custom camper. These trucks are mighty strong but know you are taxing every part of a now 55 year old rig.
06-30-2024, 11:49 AM | #5 |
Here is the most economical set of Helper springs that I found on a quick search.
Link: https://www.truckspring.com/products...elper-991.aspx Summit had some better sets that cost More.
06-30-2024, 04:59 PM | #6 |
Thanks, great points.
I like the helpers,I ve used hellwigs on my 2006 1500. My drum brakes work good, PO added hydraboost system. 4.57 gear helps up hill. I might stick to 250gal. |
06-30-2024, 11:48 PM | #7 |
Active Member
I added Timbren "rubber springs" to assist my 2000lb leafs. I think the kit was not designed for leaf suspension, so the mounts didn't work at all and I had to fabricate my own. Kind of a pain in the ass but I'm really happy with the results.
It still rides like a couch and now I can haul a full yard of dirt or rock without the rear getting all sad and squatty like a Carolina truck or whatever.
1971 Pontiac Firebird 1971 GMC C2500 |
07-01-2024, 08:33 AM | #8 |
My CG for water tank being pushed back from tool box, hurts some.
My Chev 2500HD 4dr long bed can haul 425gal tank full. It's a truck. It carried my 3200lb Lance camper "geared up" and towed Chevy wagon |
07-01-2024, 09:55 AM | #9 |
Could you change to side mount toolboxes and still have room for water tank and tools you need?
07-01-2024, 10:02 AM | #10 |
Probably could move tool box, easier to use big yruck, and settlt for 250gal max.
I heard sway bars are a .yst on front end. . I had a trailer 3500lb single axle,buy that was a mess on wash board road. |
07-04-2024, 07:19 PM | #11 |
Drove it 50mi today, getting ready for 200mi round trip soon.
07-04-2024, 07:30 PM | #12 |
07-05-2024, 06:31 PM | #13 |
425hp409
I have a set of factory overload springs that you can have if you pay the shipping. They have all the mounting brackets etc.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
Tags |
3/4-1 ton 2-wd, long bed |
