Old 07-04-2024, 07:36 PM   #1
skokie
skokie's Avatar
Upgrading to POSI
My 68 C10 will eventually have a 700r4 installed and the 3.07 open will be replaced with a 3.42 or 3.73 POSI. Have not made up my mind on the ratio yet.
What units are you guys using for your POSI? I have been told the GM80 is good and bad and there are others as well. Would like to get your opinions.
Thanks!
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 07-04-2024, 08:43 PM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Upgrading to POSI
Eaton is the stock unit, and they are stout and rebuildable. I've had good luck with Auburn. I prefer 3.73 in a halfton truck.
Old 07-04-2024, 08:43 PM   #3
LS short box
I like and use Detroit Tru Trac. No posi friction lube needed.
Old 07-04-2024, 08:45 PM   #4
oneshotkyle
I recommend true trac also. No clutches to fail and no additives. Theres a damn good reason all the diesel pickups run them
oneshotkyle is online now   Reply With Quote
Old 07-04-2024, 11:50 PM   #5
truckster
truckster's Avatar
I also have a Tru Trac. I love it.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 07-05-2024, 08:38 AM   #6
A1971Blazer
A1971Blazer's Avatar
For street use you, can't beat the Eaton TrueTrac,
I have them in all 3 of my trucks
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 07-05-2024, 10:09 AM   #7
dagnabbitt
dagnabbitt's Avatar
I have a 700r4 with an Auburn 3.73, haven't put a lot of miles on it but its fun.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 07-05-2024, 12:07 PM   #8
skokie
skokie's Avatar
I will look into the Eaton TrueTrac. I plan on driving and using this truck maybe even a roadtrip or two
Thanks!
68 build thread
Old 07-05-2024, 12:51 PM   #9
Luke87gt
Did the i6 equipped trucks have 3.73 from the factory in the 12bolt?
1969 C10 Shortbed
Wanted (pm me):
- Pair of 275/60/15 tires
Luke87gt is offline   Reply With Quote
Old 07-05-2024, 01:14 PM   #10
bnorth
Mine doesn't, but it's a 292 not a 250. I have 4.11s
1970 C10 l/b 292/4spd
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=811062
bnorth is offline   Reply With Quote
Old 07-05-2024, 02:32 PM   #11
72SB
the standard gear seems to be 3:73 in the I6 1/2 tons.
Get Eaton vs Auburn LS diff. Or the Eaton TruTrack. My $.02 is I prefer the LS vs TruTrack.
700R4 has a VERY low 1st gear so I would go 3:42's to keep the Fwy RPM's down.
72SB is offline   Reply With Quote
Old 07-05-2024, 03:04 PM   #12
weq92f
weq92f's Avatar
700r4 here with 3.73 Eaton posi. The low 1st gear helps it get off the line quick and the rear gear keeps the RPMs in check at speed. 2000 RPM = ~75MPH, 2150RPM = ~80MPH.
Hth,
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 07-05-2024, 05:56 PM   #13
skokie
skokie's Avatar
I have a 2001 gmc sierra 1/2 ton with 3.42s. 80 mph is 2100 rpm. Roadtrip cruiser
68 build thread
Old 07-05-2024, 09:18 PM   #14
'68OrangeSunshine
My '68 C/10 came with a 292 L6 and 3.73 rear.
Old 07-05-2024, 10:35 PM   #15
Luke87gt
I’ll verify next time I have the truck in the air but if it already had 3.73s that would be awesome and one less thing to worry about.
Can anyone elaborate on the Eaton LS vs Tru Track?
What is the cost difference? I want to be sure that when I pop that clutch both tires go up in smoke for many years to come on the street.
1969 C10 Shortbed
Wanted (pm me):
