Old 03-21-2024, 10:18 AM   #26
Shortnwide4x4
Shortnwide4x4's Avatar
Re: Well, I did it again.....
That looks like a great start, good score!
Shortnwide4x4 is offline   Reply With Quote
Old 03-21-2024, 10:47 AM   #27
1970cstblazer
1970cstblazer's Avatar
Thumbs up Re: Well, I did it again.....
Originally Posted by 57taskforce View Post
That’s why mother GM blessed us with the all mighty SM-465!
Amen!
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 03-21-2024, 07:03 PM   #28
68Gold/white
We're all looking forward to more pictures, especially when it's all on Leon's property.
Doesn't look like too much is missing.....but engine looks like it might have water in it...
68Gold/white is offline   Reply With Quote
Old 03-21-2024, 07:42 PM   #29
JDL
JDL's Avatar
I know that truck.
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline   Reply With Quote
Old 03-21-2024, 09:06 PM   #30
LockDoc
The Older Generation
LockDoc's Avatar
Thanks....
Looks like everything is there. I got it home late this afternoon but didn't have time to mess with it. I will know about the engine in the next few days. It is supposed to rain and snow over the weekend
Originally Posted by JDL View Post
I know that truck.
Yep, I looked at it back in 2019 but the guy that owned it then wanted too much for it.
http://67-72chevytrucks.com/vboard/s...d.php?t=790724
He later sold it to the guy I just bought it from.
Leon
Old 04-08-2024, 10:26 PM   #31
LockDoc
LockDoc's Avatar
I now have the engine running and it sounds pretty good. The radiator had a leak in it so I had to fix that. Don't flame me for the back country core support brace...
The under dash wire loom was a mess so I pulled it all out. Notice the two fuses with aluminum foil wrapped around them... .. I also removed the A/C components and wiring.
The cluster had a couple of non-stock gauges in it so I disassembled it and removed them. I think I have another complete cluster I can use for it so I may just use this one for parts.
Leon
Old 04-09-2024, 12:19 AM   #32
jjzepplin
jjzepplin's Avatar
In for this. You are reinstalling the A/C right? If not - let me know. Florida is hot!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 04-09-2024, 02:39 PM   #33
57taskforce
All about them K’s
57taskforce's Avatar
Interesting that it’s an ac truck without a clutch fan. Never seen that before. Probably a Po’s shenanigans.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is online now   Reply With Quote
Old 04-09-2024, 03:55 PM   #34
54blackhornet
54blackhornet's Avatar
Man you got it torn down quick ?
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 04-09-2024, 06:06 PM   #35
LockDoc
LockDoc's Avatar
I do have a complete Vintage air setup I could put in it but We will have to see where this is going first.
There are a lot of things changed on this truck so all bets are off on that....
I just hope I can get it put back together as quick...
Leon
Old 04-09-2024, 08:28 PM   #36
doowopper
I'm watching.
doowopper is offline   Reply With Quote
Old 04-15-2024, 10:55 AM   #37
LockDoc
LockDoc's Avatar
Replacement under dash wire loom and complete stock cluster are now in. Both items in good shape that I had on hand. I also dug out a pretty decent engine compartment main power/headlight loom that I am going to use. I think I can save the starter/ignition loom. I will pull it out this morning and check it out. If not I have one I can use. I also replaced the dash pad with a maroon one I had. It has a couple of small cracks on it but it is in a lot better shape than the black one that was on it. Next I am going to check out the brakes and start bolting the sheet metal pieces back on it.
Keep in mind that this is not a rebuild or restore project but a get it running and driving safely project because I am probably going to have to sell it since I just purchased my Uncles all original '69 1/2 ton pickup.
Leon
Old 06-02-2024, 12:29 AM   #38
LockDoc
LockDoc's Avatar
I really haven't been dragging my feet on this but I have had a lot of other irons in the fire the last couple of months. I am finally back on it and making pretty good progress on it. New front calipers, pads, and master cylinder are installed. The rotors cleaned up good and are in good shape. Starting to bolt the sheet metal back on it. I had to fix a pretty bad crease in the top of the drivers fender. It had been fixed before and was really thin in spots. I finally got it squared away and it looks pretty good. I hope to bolt the hood and front bumper back on it in the morning.
As I mentioned before, this is not a re-build, this is get it driveable and safe project. Someone else can do the re-build on it..... I drove it around the yard a couple of days ago and it actually runs pretty good.
Leon
Old 06-02-2024, 01:02 AM   #39
68bowtie
68bowtie's Avatar
Mean machine. Looking good!
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
Old 06-02-2024, 09:54 AM   #40
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks great!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 06-02-2024, 10:57 AM   #41
1970cstblazer
I really need a K20 in my life at some point. Need to finish the '70 Blazer and get the C50-C60 dump truck I've always wanted first. LOL
Old 06-02-2024, 12:28 PM   #42
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: Well, I did it again.....
i wish you could send some of your energy out my way, every time i walk out to my 69 suburban i get overwhelmed and walk away. mine needs a solid weekend of work and would be drivable but i just can't bring myself to jump on it
you are making quick work on yours
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 06-02-2024, 02:13 PM   #43
54blackhornet
Man you sure get stuff done quickly ! Your knowledge of the electrical stuff is just incredible !
71 C-20
07 Magnum RT AWD
Old 06-02-2024, 11:44 PM   #44
LockDoc
LockDoc's Avatar
Thanks!
Originally Posted by Ol Blue K20 View Post
Looks great!
Thanks Dale.
That should be doable in a couple of years....
All you have to do is one little thing every evening. It doesn't have to be anything major, just keep pecking away at it. Before you know it it will be done.
Thanks.
Almost everything I know was learned from the members of this board. Some of it was trial and error but we won't talk about that....
I added the hood and front bumper this afternoon. On a stock height truck I can get the hood on by myself but with the 4" lift this truck has I had to call in some help. I still have some adjustments to make.
LockDoc
Leon
Old 06-03-2024, 08:09 AM   #45
LT7A
Man that looks cool. If you sell it, I'd be very tempted if I was a bit local-er. Looks like some of that white over-paint might come off with a pressure washer, and maybe the rest of it with some elbow grease.
LT7A is online now   Reply With Quote
Old 07-01-2024, 12:06 AM   #46
LockDoc
LockDoc's Avatar
I sold this truck Saturday. It went to a local guy I know and he builds some nice stuff.
Leon
Old 07-04-2024, 06:52 PM   #47
BIG ORANGE
BIG ORANGE's Avatar
Super impressive I love it, I showed my wife, she couldn't believe it.......
Great score brother,
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 07-04-2024, 10:08 PM   #48
Ol Blue K20
Congratulations Leon, I think you saved another one!!
Dale
Old 07-04-2024, 10:54 PM   #49
LockDoc
LockDoc's Avatar
Thanks Donnie.
Yep, pretty sure I did. That's a win in my book....
Leon
