Upgrading to POSI
My 68 C10 will eventually have a 700r4 installed and the 3.07 open will be replaced with a 3.42 or 3.73 POSI. Have not made up my mind on the ratio yet.
What units are you guys using for your POSI? I have been told the GM80 is good and bad and there are others as well. Would like to get your opinions. Thanks!
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
![]() Join Date: Feb 2002
Re: Upgrading to POSI
Eaton is the stock unit, and they are stout and rebuildable. I've had good luck with Auburn. I prefer 3.73 in a halfton truck.
I like and use Detroit Tru Trac. No posi friction lube needed.
![]() Join Date: Jan 2015
![]() Join Date: Jan 2001
I also have a Tru Trac. I love it.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
![]() Join Date: Nov 2013
For street use you, can't beat the Eaton TrueTrac,
I have them in all 3 of my trucks
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
![]() Join Date: Dec 2014
I have a 700r4 with an Auburn 3.73, haven't put a lot of miles on it but its fun.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
I will look into the Eaton TrueTrac. I plan on driving and using this truck maybe even a roadtrip or two
![]() Thanks!
Did the i6 equipped trucks have 3.73 from the factory in the 12bolt?
1969 C10 Shortbed Wanted (pm me): - Pair of 275/60/15 tires |
Mine doesn't, but it's a 292 not a 250. I have 4.11s
1970 C10 l/b 292/4spd Build: http://67-72chevytrucks.com/vboard/s...d.php?t=811062 |
the standard gear seems to be 3:73 in the I6 1/2 tons.
Get Eaton vs Auburn LS diff. Or the Eaton TruTrack. My $.02 is I prefer the LS vs TruTrack. 700R4 has a VERY low 1st gear so I would go 3:42's to keep the Fwy RPM's down. |
700r4 here with 3.73 Eaton posi. The low 1st gear helps it get off the line quick and the rear gear keeps the RPMs in check at speed. 2000 RPM = ~75MPH, 2150RPM = ~80MPH. Hth, -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#13 | |
My '68 C/10 came with a 292 L6 and 3.73 rear.
#15 |
I’ll verify next time I have the truck in the air but if it already had 3.73s that would be awesome and one less thing to worry about.
Can anyone elaborate on the Eaton LS vs Tru Track? What is the cost difference? I want to be sure that when I pop that clutch both tires go up in smoke for many years to come on the street.
